Sponsored by: Real Truck
trailer brake
Old Mar 16, 2016 | 12:48 PM
renoduckman's Avatar
renoduckman
trailer brake
Never used a trailer brake before. So does my 02 F250 have a plug under the dash some place to hook one up?
Thanks Joe
Old Mar 16, 2016 | 01:36 PM
senix's Avatar
senix
Yes, check your glove box for the adapter. that will allow an aftermarket TBC to connect to the wiring harness.
Old Mar 16, 2016 | 02:00 PM
sunuvabug's Avatar
sunuvabug
I wanted a brake controller for my 2001 SD to pull my single axle, electric brake equipped, 16' cargo trailer. I picked up a used Tekshona Prodigy 2 (1 generation older than currently available) for my setup off of Kijiji (like Craigslist). Works like a charm and for half the price of a new one.
I had to buy a vehicle specific cable (etrailer.com) to connect the brake controller to my Ford truck ... I believe the cable was around $15. I ordered an additional controller bracket so I could disconnect and move the controller unit to my RAV4 and use it with that vehicle as needed.
My 2001 F250 grey connector is under the dash on the right hand side of the steering column ... not too hard to find but not much room to work with. Keep in mind my truck had the factory installed camper package with hitch receiver with complete 7 pin wiring setup right from the factory so I did not have to do any additional wiring. It was a simple plug and play with the controller. Once installed, you will have to "tune" your controller based on load and the desired braking assist needed/wanted. This too was simple to do.
Hope this helps. ~ BugJr ~
Old Mar 16, 2016 | 04:20 PM
renoduckman
Thanks.
Found the adapter in the glove box .
Always learn something on the site!
Joe
Old Mar 16, 2016 | 05:17 PM
senix's Avatar
senix
one added cost you don't have, great. Should plug right into the TBC you choose.
Old Mar 16, 2016 | 06:14 PM
1979 Ford's Avatar
1979 Ford
I went to Amazon for my last controller and harness.
dnewton3
Apr 8, 2018 05:58 PM
KatieCawood
2009 - 2014 F150
24
Nov 30, 2014 07:41 AM
jfmaz
Aug 27, 2010 03:35 PM
RussB
Nov 3, 2008 07:57 PM
62BigBlue
Mar 25, 2003 04:07 PM
