Electronic Trailer Brake Controller
Old Feb 3, 2010 | 03:47 PM
jfmaz's Avatar
jfmaz
I have a 97 F350 CC 4X4, 7.5g motor. It has a wiring plug under the center of the dash near the floor that the EVTM book says is for electronic trailer brake controller.
Anyone have info on this, is it a plug in unit that I can purchase?
My truck has the 7 way factory plug at the back, plugged int two harness connections under the rear bed area.
Not sure on the brake control, haven't had the truck long enough to pull a trailer with brakes but plan to pull the skid-steer around with it.
Any info is appreciated!
Jeff
Old Feb 3, 2010 | 03:55 PM
rla2005's Avatar
rla2005
I installed a brake controller from Valley Industries (Valley Industries ) Works great. I purchased the cable to attach it at the local farm store.
Old Feb 3, 2010 | 04:15 PM
subford's Avatar
subford
As rla2005 says you need to buy a pigtail at a trailer outlet or Farm store.
Then splice it to the wires from the Brake Controller.
The pigtail C210 in diagram below (Dash Connector #18260):
Old Feb 4, 2010 | 08:05 AM
jfmaz's Avatar
jfmaz
[quote=subford;8462274]As rla2005 says you need to buy a pigtail at a trailer outlet or Farm store.
Thanks Subford!!
Jeff
Old Aug 24, 2010 | 12:40 PM
94WhiteF250's Avatar
94WhiteF250
Little Help With Brake Controller
Hey guys I have been reading posts all morning about hooking up a brake controller. My 94 F250 is all pre-wired for it. 7 plug connection in the back, relay box up front, and the 5 plug connector under the dash.
When I buy the controller, I am also going to purchase that little pig tail the C210 one. Once I have that and the controller, all I have to do is splice the wires into the controller and then plug it in?
Is there anything else involved in this?? Just splice it in, plug it in and I am, ready to go??
Thanks a lot for all your help guys!
Old Aug 24, 2010 | 05:38 PM
subford's Avatar
subford
94WhiteF250,
You have all of the above right.
Old Aug 27, 2010 | 02:58 PM
strider3700's Avatar
strider3700
Can anyone tell/show me where the Blue wire from the harness comes out of the firewall?
my truck had the plug under the dash and everything works but I need to get a blue wire from the brake controller at the back to hook up to the 7 pin. I don't know if it's hidden away somewhere or if it isn't in place from the factory and I need to run a new one from the wirewall. First step is figuring out where that harness under the dash ends.
Thanks
Jamie
Old Aug 27, 2010 | 03:35 PM
strider3700
found it, thanks to this thread
https://www.ford-trucks.com/forums/9...connector.html
it ends in a 4 pin round at the back of the truck, now I just need to connect that blue to the 7 pin plug and I'm done.
old farm truck
All Things Towing
26
Sep 2, 2017 08:59 AM
KatieCawood
2009 - 2014 F150
24
Nov 30, 2014 07:41 AM
saltbranch
All Things Towing
13
Nov 26, 2013 04:36 PM
firewood truck
Electrical Systems/Wiring
Jun 2, 2011 09:30 PM
apbtpetey
13
Oct 25, 2010 10:22 PM
