Sponsored by: Real Truck
Default spring trivia
Old Mar 16, 2016 | 07:28 PM
MadWolf's Avatar
MadWolf
I read all the spring threads I could find, but I still have questions. If anyone's up for some spec trivia..
1. On my 15', 250, reg cab, 2wd, the door sticker sais a little over 3800#.for front. So that would be what springs? 4200?
2.(F250) What would the default front spring's weight be on a 16', 250 xlt, regular cab, fx4? Without Heavy service, snow prep, or camper packages. And would the snow prep get you the 6000#s? And WITH 6000s, the 250 front end wouldn't actually be higher, would it?? Or just about level?
3.(F350 SRW) What would the default front spring's weight be on a 16', 350 xlt, regular cab, fx4? Without Heavy service, snow prep, or camper packages. Does it come with the maximum, 6000#s anyway? Or do you still need snow prep to get those?
Old Mar 16, 2016 | 08:37 PM
Just Strokin's Avatar
Just Strokin
Go to this Ford website and it will give you the build info on your truck.
Select the Vehicle tab and enter your VIN.
Towards the bottom are the springs. Maybe you can then use the number to find out more info about them.
https://www.etis.ford.com/
You might need to actually look at the tags on the front springs to know what is installed.
Old Mar 16, 2016 | 09:29 PM
MadWolf's Avatar
MadWolf
That's handy, thanks. 9C34 5310 GA code G. are the ones I have now. Another chart said those are 4100? They're pretty comfortable. I'm trying to figure out what they jump up to with a 4x4, and then again with package options, then f350 etc. If I where to switch trucks. I like the way mine sits now too, just the slightest rake to it. So I'd want to end up close to that angle.
smlford
Sep 16, 2016 12:38 PM
twigsV10
Oct 31, 2015 12:30 AM
Hossy
May 18, 2004 10:10 PM
Fred H
Oct 26, 2003 09:38 PM
Shepard
Feb 11, 2002 09:24 PM
