Going Solar
Old Mar 18, 2016 | 05:25 PM
  #46
silverbullet6oh's Avatar
silverbullet6oh
Originally Posted by diesel_dan
Yeah, well at least at 59.99999 years old I remembered!
Now I don't have to come install it for you, do I?!
Okay Scott, you can pipe down now!!! Haha!!
Here is something I found. Need to dig deeper into how they are built:
Flexcell Sunslick 14WATTS Flexible Solar Panel for Marine Yachting | eBay
They also build one in a 27 watt size that is a tad over 2' wide...
So what about the panel? They are made in Switzerland, I can't find anyone that sells the 27 watt but you could use 2 - 14s, though likely one would do it. I found the best price on one for $40 plus $10 shipping on Amazon, you might be able to get them to ship two for that price. And the eBay seller has a "make offer" on his listing, so you could try that route too. You should be able to get a couple for $90 to your door.
I did a little research on the same controller I use: a Morningstar SG-4 and it can be permanently hooked to a battery set that also has other charging inputs, without harming the SG-4. Shop around and you can get one in the $25-$30 range to your door.
So we get you 28 watts which will be more than sufficient for $90 and say it's $30 for the controller (tho I did get mine for less and you can too), and we are at $120 with money left in your budget for wire and connectors
Okay, I like that setup. I am seriously thinking about this one. With the SG-4 do I have to wire in the connections or is there a plug in version?
The only concern I have is that the Flexcell unit doesn't look like it have the conventional plug style I see on most solar wiring.....
How would I connect it?
I am also considering this one as a beginner pack. I know its tempered glass and only 10 watts:
Amazon.com : ECO-WORTHY 10W PV Polycrystalline Solar Panel System kit W/ 3A Charge Controller & 30A Battery Clips : Patio, Lawn & Garden Amazon.com : ECO-WORTHY 10W PV Polycrystalline Solar Panel System kit W/ 3A Charge Controller & 30A Battery Clips : Patio, Lawn & Garden
Thanks again for all your help Scott
Old Mar 18, 2016 | 05:57 PM
  #47
diesel_dan's Avatar
diesel_dan
Actually a lot of panels use an MC-3 or MC-4 connector, I don't know what this Swiss one uses. I figure you'd cut off anything that didn't match and solder on the right connector. Yes the SG-4 needs to have whatever connector type you are using put on both the in and out.
I've got no comment on the all-in-one you found other than we could have been looking at all kinds of different stuff, but it seemed there was a "plan".
Have fun with whatever you decide to do.......
Old Mar 18, 2016 | 08:48 PM
  #48
silverbullet6oh
You are correct about the plan.
It's still hard to see all this working with no previous experience. So I am still kinda worried about all of it. Like screwing it up. That's all. But I guess I should remember I have this community for all the help.
Old Mar 18, 2016 | 09:23 PM
  #49
WatsonR's Avatar
WatsonR
Been watching this thread... curiously.
Why the controller? If the solar panel had a cigarette plug, why not just plug directly into the power port. It would charge during the daytime only and at that wattage/voltage output, keep the battery full and probably charge to 100% pretty fast.... if the battery isn't overly low to begin with.
If you look at the sunpack, its roll able and equipped with a cigarette lighter plug. The 14w rated sunpack is 59" long, probably fit across the dash.
Old Mar 18, 2016 | 09:29 PM
  #50
silverbullet6oh
Your correct about everything you said. But, I want it controlled so that it's just there. Not having to mess with it, or forget to plug it in, and it will make sure that it never overcharges the battery.
Old Mar 18, 2016 | 10:22 PM
  #51
WatsonR's Avatar
WatsonR
this would work great for keeping on the dash when I'm on travel for weeks at a time. I park the truck and leave it, week or two later, drive it home.
I'd bet that the controller could be added into the cord of the panel. Clip the wires, insert the controller and put the plug back on. Then just plug the thing into the power port, should do everything from there by itself. Roll up and put under the seat until I travel again.... now to find the sunpak on line.
Old Mar 18, 2016 | 11:36 PM
  #52
diesel_dan's Avatar
diesel_dan
exactly. and the controller can be added in the middle -- why not have a sophisticated charger, for a tiny bit more, but particularly if you have more power on the front end...
If it is a 5 watt panel, fine, run it direct. 10 watt maybe, depending on how long you are gone. 15 (or so) watts and above? I don't want to worry...
But that's just me...
Old Mar 18, 2016 | 11:42 PM
  #53
diesel_dan's Avatar
diesel_dan
It isn't much money, even if it is a total loss. It isn't much risk of screwing it up, because it is a positive lead and a ground, and that is it -- you are buying the stuff that had to be engineered...
Old Mar 19, 2016 | 12:24 AM
  #54
WatsonR's Avatar
WatsonR
Well that's a pretty good price. Panel with charger and 12v plug for the power port...$90. Roll it up and put under the back seat. Plug it in, throw the panel on the dash and slid a sun shield behind to keep heat down in the truck.
Last question Scott... it say rated to +60c, that's 140f and I know the dash can get hotter than that, probably more like 180*, trucks a black one with black interior. Think it will hurt the panel?
Old Mar 19, 2016 | 10:43 AM
  #55
diesel_dan's Avatar
diesel_dan
I'm not sure which one you are looking at Randy, but in general panels get less efficient with heat (and put out more power the colder it is). I doubt anything in the panel will "burn up" at 140 deg F, but that is more likely the rated range for the stated output. So over that temp will be a gradual reduction in power output.
So shoot us a link to what you found
I run my set-up on the wife's Expy dash and it worked just fine -- doesn't sound as flexible as what you are looking at (would be cool if they integrated one into a sunshade! One step process )
Old Mar 19, 2016 | 11:30 AM
  #56
WatsonR's Avatar
WatsonR
The Flexcell Sunpak is a nice unit, but $$ is an issue for that model. Not available here in the US and then cost prohibitive at 177euro ($200US). Not paying that for a < 1amp charger.
http://www.solarc.de/cms/media/Downl...207_14%20W.pdf
However, the Flexcell Sunslick is a nice looking panel and at $50, basically a no risk, good deal.
Just like you posted, SG4 controller, Flexcell SunSlick 14w panel @ .9amp and a $3 12v male power plug. $90 and 20 minutes work. Add the controller in the middle, attach the power plug. Plug it into the power port, put up your panel and walk. The panel at 52" would cover most of the windshield and complete under 2lbs, wished it could be folded, but i think it could be rolled fairly small.
Would be cool if the controller desulfated the batteries!
Old Mar 19, 2016 | 11:40 AM
  #57
diesel_dan's Avatar
diesel_dan
Yeah, I saw the Flexcell, just didn't see it available all set up like you mentioned, or even a US seller. Did you look at some of the other foldable units out there? Several on Amazon that fold up into a small square...
Oh and bonus round: Pulse Width Modulation (PWM) does desulfation of your batteries
Here's a white paper from Morningstar:
http://www.morningstarcorp.com/wp-co....-Why-PWM1.pdf
Old Mar 19, 2016 | 12:35 PM
  #58
WatsonR's Avatar
WatsonR
I looked at some others, storage is an issue and possible damage by passengers in the back seat. It needs to be put away, out of the way of feet stomping on it and moving a square panel around would become a pain.
This one is pretty nice, fold-able and 27w for 2.5amp output, should do the job nicely! Add the controller and a plug, $140
Amazon.com: Instapark® Mercury27 Portable & Foldable 27 Watts Solar Battery Charger with DC 12V Output: Automotive Amazon.com: Instapark® Mercury27 Portable & Foldable 27 Watts Solar Battery Charger with DC 12V Output: Automotive
Has multiple power connections USB/12v and would work great in camp for a cell phone/laptop charge. I'm thinking this would also fit in the back pocket of the seat. Still relatively low cost and extremely portable.
Charge controller here
Amazon.com : Instapark INCC1205 12V / 5A Waterproof PWM Solar Charge Controller : Patio, Lawn & Garden Amazon.com : Instapark INCC1205 12V / 5A Waterproof PWM Solar Charge Controller : Patio, Lawn & Garden
Makes it $115
Old Mar 19, 2016 | 01:32 PM
  #59
diesel_dan's Avatar
diesel_dan
Charge controller here Amazon.com : Instapark INCC1205 12V / 5A Waterproof PWM Solar Charge Controller : Patio, Lawn & Garden
Makes it $115
All I see you'd have to do is put a different connector on the panel side. It seemed like I saw some cheaper foldable ones, but that's pretty good for $99 and 27W.
I'm not familiar at all with that controller but it looks clean and I like that it has indicator lights, something the unit I'm using doesn't have. I have used several Morningstar controllers now and one Steca (German) and all are working fine.
I think you put together a winner!
Old Mar 19, 2016 | 01:55 PM
  #60
WatsonR's Avatar
WatsonR
Don't think I even have to do that, the controller has the same plug as the panel. Just cut the battery clamps off and add a male 12v cigarette plug to fit the power port... done in 5 minutes.
thanks for the knowledge you shared.
Yahiko
Arizona Chapter
Oct 17, 2016 12:46 AM
FICMrepair.com
Sep 29, 2016 10:27 PM
kawa
26
Apr 8, 2009 07:08 PM
sglaine
New Hampshire Chapter
19
Feb 25, 2008 06:47 PM
