Y-pipe to turbo hell
Old Feb 24, 2016 | 05:19 AM
DickNitro's Avatar
DickNitro
Going through hell to install a new turbo.
I've been through this before, but just once. Last time I was able to lightly pry up on the turbo - lining it up to the y-pipe then hit the v-clamp (like I had 3 arms) and it was good. Now I have a different turbo and the y-pipe is about 1/8" too far away towards the drivers side headlight. I have no means of pushing it. Hammering it with a pry bar to catch the lip is not working. I have been fighting like crazy to line this up.
I've heard of people loosening the y-pipe bolts at the exhaust manifold to allow wiggle room but those bolts look waaay rusty and I'm scared of cracking them off/stripping the head off. Should I just soak them with wd 40 or ph blaster and pray?
All help is appreciated
-Dick
Old Feb 24, 2016 | 05:39 AM
WatsonR's Avatar
WatsonR
Soak them several times.
npccpartsman's Avatar
npccpartsman
That's exactly what you should do. I ALWAYS loosen my y-pipe bolts when I'm moving the turbo (don't forget the EGR cooler). It just makes lining everything up SO much easier and you don't chance cracking flex tubes and breaking clamps. BTW--the clamps will not align the y-pipe, they are only for sealing the pipes together.
Old Feb 24, 2016 | 05:40 AM
KDAVID1's Avatar
KDAVID1
Is it a stock turbo? what year truck?
I've found that when the turbo is seated properly on the pedestal no grunt work is needed. Now this is on a 2006 so if older not sure. It does take a bit of effort to get it seated properly on the pedestal though.
Old Feb 24, 2016 | 07:27 AM
texastech_diesel's Avatar
texastech_diesel
Token Redneck
X2, you aren't going to get it lined up without taking the pipes loose.
You need four of each of these hardware numbers:
W300013
W300013
Look at pages 7-9 in this .pdf:
Old Feb 24, 2016 | 07:30 AM
DickNitro's Avatar
DickNitro
That's what I'll do then. Thank you guys for the help and the part #'s. I'll post any progress (or lack thereof)
-Dick
Old Feb 24, 2016 | 07:31 AM
WatsonR's Avatar
WatsonR
W300013
W300013
they are the same number
Old Feb 24, 2016 | 07:58 AM
Toreador_Diesel's Avatar
Toreador_Diesel
FTE Leadership Emeritus
Maybe I'm just blessed like you, but I've never had to fight a turbo to get it to seat.
I'm always the guy that everybody calls after they've fought for a few hours, then I show up, spend a few minutes and get: "How the heck did you do that?!?!? "
Old Feb 24, 2016 | 08:09 AM
navistarnut's Avatar
navistarnut
My biggest problem was convincing myself that I didn't damage the return tube o-ring after setting it down on the pedestal, to the point I actually removed it twice since it didn't "feel right", and the third time actually replaced the o-ring(had a spare for some reason). Must have been a case of temporary OCD.
Old Feb 24, 2016 | 11:03 AM
Bullitt390's Avatar
Bullitt390
Certified Thread Hijacker
I have had a couple fight me a little, for those I use the ratchet strap method.
I usually make it a habit to loosen the driver side manifold to y-pipe if the pipe doesn't line up by hand otherwise.
Helps if the turbo is seated with the bolts installed, but left loose.
Josh
Old Feb 24, 2016 | 11:46 AM
dannyboy950's Avatar
dannyboy950
You may wind up haveing to use all the mentioned procedures.
Some of the trucks I used to work on I got in the habit of just cutting off the bolts holding the pipes to the manifold and replaceing them with anything that will fit. They are just a long bolt and nut.
Old Feb 24, 2016 | 12:20 PM
KDAVID1's Avatar
KDAVID1
The very first time I tried to put it in it took me forever and it still wasn't right. Was told you can't pull it together with the clamp. Used a crow bar to move the turbo around. Heard a clunk and there it was perfect. Been that easy ever since--jiggle,clunk,good to go.
Old Feb 24, 2016 | 02:37 PM
DickNitro's Avatar
DickNitro
Yeah there is a very clearly defined lip on these things that fit together like a puzzle piece. Last time I heard the klunk, but that was my old turbo. Maybe I should split this one in half and use the exhaust side of my old one! the only problem was my unison ring actuator dowel. All else was ok
Old Feb 24, 2016 | 07:40 PM
texastech_diesel
Token Redneck
Copy/paste fail
4 of each:
W300051, Y-pipe nuts
W300013, Y-pipe long bolts
Old Feb 24, 2016 | 11:10 PM
DickNitro's Avatar
DickNitro
Well the good news is i've managed to loosen the most accessible bolt on each side. The real question is how the &@%#* do I get to the top bolts without the half moon wrench? I can't even get my hand in them small spaces.
