64 econoline van 4sp
Old Mar 11, 2016 | 01:02 PM
Rollen's Avatar
Rollen
have 3sp man trans in my 64 econoline would like to put 4 sp in it ! i know that ford had the 4 sp opp for a few years ,is there any other 4sp that can be retro fitted to fit a early econoline ?
Last edited by Rollen; Mar 11, 2016 at 02:27 PM. Reason: put my post in wrong form
Old Mar 13, 2016 | 01:51 AM
85e150's Avatar
85e150
The major issue would be linkage. There was a Dagenham 4 speed in the early Econolines:
https://www.ford-trucks.com/forums/9...econoline.html
https://www.ford-trucks.com/forums/1...-the-tree.html
Pretty rare, and what do you have when you do get one?
As for other 4 speeds, you would be having to fabricate shift linkage or adapt Dagenham linkage if you could find it.
What engine do you have?
Old Mar 14, 2016 | 08:11 AM
jas88's Avatar
jas88
I saw one of these on an E250 when I was in high school in the 70s - it was 4 on the tree. Never seen one before or since.
Old Mar 14, 2016 | 07:34 PM
EmilBarnabas's Avatar
EmilBarnabas
The 4-speed transmission was available on the Econoline in 1963 and 1964.
Econoline Transmissions
Most of the discussion I have seen is that owners did not like the gear ratios in the 4-speed and replaced it with a 3-speed.
http://vintage-vans.forumotion.com/t...eed-vs-3-speed
Old Mar 14, 2016 | 07:56 PM
85e150's Avatar
85e150
Not sure how that would have been possible. 4 on the tree or even 4 on the floor were never offered in an E250.
Old Mar 15, 2016 | 06:57 AM
tjc transport's Avatar
tjc transport
i ain't rite
yes they were.
as said above, the four speed was an option in 1963, and 1964.
the one i ran had issues with the linkage and would bind up in two gears.
we ended up pulling the trans out, stripping the linkage off the column, and putting an automatic in with cable shifter.
Old Mar 15, 2016 | 07:58 AM
jas88's Avatar
jas88
Well my memory ain't what it used to be, but my recollection was this was a Falcon Econoline type van of early 60s vintage. It was a van for a plumbing business and I thought it said "Heavy Duty" on the side. That may not have been called E250 at that time, but it looked like a bigger, heavier van, with long wheelbase and larger wheels and tires, like an F250 would have vs. an F100. Was such a thing available from Ford in '63-'64?
I see the "Heavy Duty" option started in 1964, so this must be what I saw?
Old Mar 15, 2016 | 09:42 AM
tjc transport
i ain't rite
yup. the one we had was a public service electric and gas 64 heavy duty with doors on both sides. it was their painters van.
had a 170 with 4 speed on the column. bought 5 of them in 74 for $200. sold the 4 good ones after painting them one color, and kept the painters van.
we ran it around for the summer, then took it to california in spring of 75. sold it there with the automatic trans in it for a grand and flew home.
Old Mar 15, 2016 | 08:20 PM
85e150's Avatar
85e150
I do not doubt you could have a 4 gear in a HD version in '63-4. But they were not designated as "E250s" as post 3 indicates.
Econoline Model and Body Style
Old Mar 16, 2016 | 08:40 AM
tjc transport
i ain't rite
i missed that part. if i remember correctly the E-250 designation did not even start until the second generation body style came out in 1968
Old Mar 16, 2016 | 09:56 PM
85e150's Avatar
85e150
I'm thinking the 3rd gen starting in '75. I think the '68-'74s used "E200" and "E300". Why, here's one now:
Hemmings Find of the Day ? 1973 Ford Econoline E300 van | Hemmings Daily
Dana 60 full floater. I should buy this, but I want to live to see the morning.
Old Mar 18, 2016 | 10:28 AM
EmilBarnabas
There were no "bigger" Econolines from 1961-1967. The longer Econoline was called a Super Van, and was 18" longer at the back end. The wheelbase for all 1961-1967 Econolines was 90". No long-wheelbase option.
The vans with 1-ton GVW rating had thicker frames and an extra leaf spring, so you could say they were heavier.
I have a 1964 Heavy Duty Econoline rated at 1 ton that came with 13" tires. Ford used more plys on the tires rather than larger size to get the higher load capacity.
All of the 1961-1967 Econolines and Falcon buses were E100 models, but Ford further confused the situation by using a similar designation, also called model, to designate the body style, window configuration, GVW, etc . See here Econoline Model and Body Style
Old Mar 22, 2016 | 05:10 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
4 on the tree not limited to Citroen ID19/DS21 & Mercedes-Benz 219/220 .. as you can see.
Old May 22, 2016 | 12:21 AM
wblynch's Avatar
wblynch
I helped a friend put a four speed Mustang transmission in an Econoline back around 1970. We used the three speed shifter to control the four forward gears and made a separate lever on the engine compartment for the reverse gear.
Backing in and out was a busy affair.
Old May 22, 2016 | 01:28 PM
NumberDummy
No such thing as an E250 prior to 1975.
1961/67: E100 / 1969/74: E100/200/300 / 1975/78 E150/250/350 / 1979/83 E100/150/250/350 / 1984/2014 E150/250/350.
