Upper Battery Bracket?
Old Mar 8, 2016 | 08:46 AM
sonny1965's Avatar
sonny1965
I am trying to finalize my under the hood build
Does anyone have a picture or part number of the upper battery
bracket that goes from the battery mounting bolts to the
radiator support. I know it had one at one time because the
screw was in the radiator support
Truck is a 1965 sb/352/3 on the tree
Old Mar 8, 2016 | 09:46 AM
TA455HO's Avatar
TA455HO
Lead Gopher
Now, remember, some of these drawings are just "typical" of the installation and may not be spot on to all given years shown at the bottom of the drawing.
Given that, I bet you're talking about this bracket
Name:  Battery Hold Down.jpg
Part number is
C5TZ-10A691-A
I do not see any available NOS. Bill has a few more resources than I do.
Used would probably be a good option.
The drawing above shows the later fiber-reinforced battery hold down clamp (10718) that I think they started using in 1967 or 1968.
The 1966 battery hold down clamp (10718) is all metal, round like bar stock across the top, with a rubberized coating. Battery acid could get under the rubber coating and start to eat away at it. Then it was only a matter of time.
I hope that helps some. If you want a picture of the 10718 hold down I can take one or two pics of one of those.
Old Mar 8, 2016 | 12:52 PM
sonny1965's Avatar
sonny1965
Battery Bracket?
Thanks TA455HO
That is exactly the bracket that must have been on it.
I will see if I can find one or make one
Thanks again Sonny
Old Mar 8, 2016 | 01:04 PM
TWONY's Avatar
TWONY
I have always wondered what should be there but Napa seemed to have something that worked. I love the PDF picture, that could come in handy. When you think these older trucks are simple, you have an odd one. Thank you fella's for the information.
Old Mar 8, 2016 | 02:19 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Originally Posted by TA455HO
Part number is: C5TZ-10A691-A 1965/66 F100/250 2WD 240/300/352
I do not see any available NOS. Bill (NumberDummy) has a few more resources than I do.
No Ford dealer or obsolete parts vendor has any.
Ford replaced the original battery hold down in 1970 with DODZ-10718-B (replaced DODZ-10718-A). It's molded plastic, also used on 1970/72 Maverick/Comet.
CARPENTER NOS OBSOLETE PARTS in Concord NC (800-476-9653) has 3,776 of the original DODZ-10718-A part number.
SVTDriver97
26
Aug 2, 2018 10:56 AM
unibody62
Jan 12, 2017 07:03 PM
chapinmesa
Dec 9, 2009 07:31 AM
Danny_Ocean
Mar 28, 2006 11:07 AM
murphy
May 26, 2005 04:06 PM
