P0443 EVAP canister code after changing intake gaskets
Old Mar 7, 2016 | 09:22 PM
jbourne84's Avatar
jbourne84
2003 E150 - 4.2 V6, seems to run/idle just fine.
I just replaced my upper intake isolator bolts, gaskets, and lower intake manifold gaskets. This was mainly to address P1131 and P1151 lean codes. The battery was disconnected for a while which I believe resets the CEL. Anyway, after some issues I was finally able to get everything back together.
I started it up and although I dont believe it was there on the first startup, I got a P0443 code. This is what I got from autozone:
Definition: Indicates a fault in the Evaporative Emission System Control Valve electrical circuit for a predetermined period of time.
The clerk said it was one of these and offered to order me a new one. He cleared the code in my van, and on my next startup and drive home (15-20 min) I had no light... I thought maybe I was in the clear and it was something residual from my work. But then on my next startup (about a 20 minutes after getting home) the CEL was back again.
Is this likely related to my intake work somehow? I dont believe I touched this part but perhaps I indirectly affected something?
Thanks for any ideas/suggestions
Old Mar 8, 2016 | 11:24 AM
jimandnena's Avatar
jimandnena
I would recheck the vacuum hose routings and connections before buying anything. The vacuum source for everything is the intake manifold so the chances are something there isn't exactly right. jim
78F2504x4
1997 - 2003 F150
Jun 7, 2013 07:13 PM
ncfirefighter46
1997 - 2003 F150
Feb 26, 2012 08:21 PM
dandydon
1997 - 2003 F150
Jun 6, 2011 06:57 PM
lifted77f250
May 15, 2009 04:38 AM
NetCommuter
1997 - 2003 F150
Jul 9, 2008 09:11 PM
