High Performance Headlights?
Old Jan 26, 2016 | 03:28 PM
Wamba's Avatar
Wamba
Greetings, I have a 2006 E-350 12 passenger van. I'm looking to upgrade the headlights. Any suggestions?
Old Jan 26, 2016 | 04:46 PM
REDOVAL's Avatar
REDOVAL
I sell custom HID Projector retrofit headlights for the 92-07 Ford vans. Shoot me an email to Stredbull18@gmail.com and I will send you the specs/options. Thanks
Scott
Old Jan 28, 2016 | 05:50 AM
JWA's Avatar
JWA
Scott's improvements are widely thought to be among the better custom assemblies being one-off made for the E-Series. He might link you to another site with several users who've been very happy with his products.
He's a bit bashful, doesn't like to toot his own horn!
Old Jan 28, 2016 | 10:50 AM
REDOVAL's Avatar
REDOVAL
JWA nailed it....
Ford E-Series Van HID Projector Retrofit lights - Sportsmobile Forum
Scott
Old Jan 28, 2016 | 10:46 PM
thi's Avatar
thi
I'm very satisfied with truck lites led. Plug and play. 3 yr warranty. $360 shipped.
Old Jan 29, 2016 | 05:01 AM
JWA's Avatar
JWA
Those at first seem to absolutely perfect for any number of reasons--I almost took the plunge myself.
Living in Ohio where snow and ice can be issues the cooler running LED headlights wouldn't work very well; incandescent sealed beam bulbs typically operate at temperatures that prevent or greatly reduce that build up.
That's just me---could be you're in a climate where the LED's would work great
Old Jan 29, 2016 | 11:24 AM
coolfeet's Avatar
coolfeet
I bought some parts from Scott last year and his delivery is amazing! He talked with me on the phone, text, and email. Expect the best!
Old Jan 29, 2016 | 05:00 PM
gman97005's Avatar
gman97005
HID's are 200% brighter than halogens and will light up the road but you will also blind every driver coming the other way and at night in the rain that might cause a problem, also every person that has to drive in front of you at night will want to pull behind you and stick their high beams up your ,,, .
May i suggest the PIAA Night Tech which is 65/55 watt, White 3600k, DOT legal, direct replacement, very highly rated and $70/pr..
PIAA | 9007 (HB5) Night Tech Bulb 65/55w 3600K, Twin Pack #10727
Old Jan 29, 2016 | 05:10 PM
KarstenP's Avatar
KarstenP
Running the TruckLite LED's in my van and stock HID headlights in my Catera I found out that the LED's do not pack that much ice and snow as the HID's do (and those are even aerodynamical). Never had a problem with LED yet.
Old Jan 29, 2016 | 08:12 PM
wiskeyVI's Avatar
wiskeyVI
WOW..I really like the looks of the black ones...
Old Jan 29, 2016 | 11:18 PM
coolfeet's Avatar
coolfeet
Are these direct fit for Ford E series vans?
Old Jan 30, 2016 | 12:37 PM
KarstenP's Avatar
KarstenP
Yes, 10 minutes each side.
Old Jan 30, 2016 | 12:45 PM
coolfeet's Avatar
coolfeet
Can post the link in your reply for the direct fit LEDs? I need 2 new head light assemblies. I may as well get a decent set and add the LEDs.
I live in the Bay Area. You could essentially drive without head lights here because there is so much light pollution. However, when I camp in the boonies, I need some good light. I have an aftermarket set bought on Ebay that is nearly worthless. The seller refunded me and let me keep them. I added a good set of head lamps and can be seen by other drivers. Put me on a dark road and it's not so good.
Old Jan 31, 2016 | 07:50 AM
KarstenP's Avatar
KarstenP
You might check this thread: https://www.ford-trucks.com/forums/1...eadlights.html
Old Feb 27, 2016 | 05:37 PM
Methodic Menace's Avatar
Methodic Menace
Anything like this for a 2010 E350?
