Transmission NP435
Old Mar 5, 2016 | 07:23 PM
T_Cooksey88's Avatar
T_Cooksey88
Transmission NP435
78 F-150 351m C6 4x4. My truck was originally np435. Owner before me swapped it to C6 from Np435. I was planning on swapping it back. Where is a good place to get a NP435 that is already rebuilt with bellhousing, shifter stick, and mount for np205. Where is a good reliable source?
Old Mar 5, 2016 | 08:00 PM
HIO Silver's Avatar
HIO Silver
Dang. Yer asking for a lot.
... start at JBG.
Old Mar 5, 2016 | 08:15 PM
T_Cooksey88
I have seen some on Novak (Complete NP435 Transmission Package), JBG has them, also toms bronco has them. I just do not know if they come with shifter. Novak comes with bellhouse and mount for 205 just nothing about shifter
Old Mar 6, 2016 | 07:51 AM
tabascom16's Avatar
tabascom16
Looking at the prices of rebuilt transmissions and shipping cost, unless you like throwing money away, source locally and rebuild yourself.
Look on Craigslist or put an ad on Craigslist saying what you are searching for. Any 4x4 NP435, T18, or T19 for a Ford will work with the same bell housing. T19s are from the 80s and is suppose to have a synchroed 1st gear and the first gear is not as steep of a granny gear (especially if you get the diesel version).
You should be able to pick up everything you want for $200-$250. A tranny rebuild kit looks to be just over $100 if you really want to rebuild it. Try and find some tutorials on the internet and just give it a try. Or have a local shop rebuild it.
Old Mar 6, 2016 | 08:40 AM
Hyperactive460's Avatar
Hyperactive460
you should be able to find what you need at a pick and pull, i put one in a guys truck for him about 10 years ago and he spent 1200.00 hundred just for the transmission alone.
Old Mar 6, 2016 | 09:45 AM
78 PEB's Avatar
78 PEB
Too bad you aren't closer...... there has been one on our local CL for months. $100
Old Mar 6, 2016 | 10:13 AM
fordguy2100's Avatar
fordguy2100
Yeah I just picked one up with a spare transmission too for $125 in Indiana.
Old Mar 6, 2016 | 10:47 AM
lafermedavid's Avatar
lafermedavid
my local yard has one,I would go that route,and rebuild it with a novak kit
Old Mar 6, 2016 | 08:03 PM
T_Cooksey88
So what I am looking for is a 78-79 F-series NP435? I've got a 460 that's going in so it'll bolt to it. Gotta get a clutch and fix the steering column for a manual shift.
Old Mar 7, 2016 | 04:03 PM
T_Cooksey88
Guy from local junkyard said he doesn't know if it's a NP435, or T-18,T-19. Quoted me $500 for the transmission. Good deal or no?
Old Mar 7, 2016 | 05:07 PM
fordguy2100
Hell no, I just bought an NP435 and NP205 for $125 off Craigslist... That's crazy. Well maybe it's a good deal around you (not sure where you're at) but here that's highway robbery
Old Mar 7, 2016 | 06:11 PM
tabascom16's Avatar
tabascom16
That junk yard owner is a swindler! Any 4wd truck from 78-79 will have the married transmission/transfer case assembly. They will be either a T18 or NP435. I would pay no more than $150 for a transmission.
Search Craigslist in your area for someone parting out a 77-79 Ford truck. Searchtempest.com might help you out as well to search a larger Craigslist area.
I am not sure how accurate this is, but it will give you an idea of some 80s trucks to look at as well.
http://www.fordification.com/tech/transID-man.htm
Old Mar 8, 2016 | 12:39 AM
AK FORD GUY's Avatar
AK FORD GUY
I'm hopefully going to go look at a NP435 and NP205, listed at $400. It's the divorced set-up and harder to come by up here.
If I get a chance to look at it, I might offer $300 - $350 for the pair.
Old Mar 10, 2016 | 09:46 AM
T_Cooksey88
Any possible problems running into clutches and the mounting of the 460 with NP435, should i get the L&L flywheel, and clutch. I've been reading up, it is a 68 thunderbird 429 with a 460 crank and pistons, so 460. Transmission is out of a 78 F150, 351m/400. What are the problems or what should i get for the motor and transmission to run and operate the best?
Old Mar 10, 2016 | 05:25 PM
lafermedavid
L$L is a proven setup,good quality
T_Cooksey88
Mar 6, 2016 11:46 AM
norvillebob
Feb 27, 2010 08:13 PM
dickydale
Jun 17, 2009 12:12 PM
Rossta86
Dec 27, 2005 01:09 PM
