rear axle flip
Old Mar 2, 2016 | 08:51 PM
ru67's Avatar
ru67
rear axle flip
Wanting to lower the rear of my 67 about 5 inches and have read a lot of the post on here.Im not going to be hauling anything just building a cruiser.By sitting the axle on top of the springs (axle flip) I noticed some of you say that you C notched the frame and some say you didnt.Is there enough travel there to not notch the frame , looks like it would be bottom out real easy. Also do you have to buy a kit or did you just cut the mount pad off the housing and reweld it on the opposite side ? also will the spring hanger brackets on the frame have to be changed or work as they are ? Thanks for any help and imformation.
Old Mar 2, 2016 | 09:26 PM
HIO Silver's Avatar
HIO Silver
Trozei can provide input on NOT notching the frame.
I used Fatman Fab's flip system, a bolt-on, but couldda easily fabbed it up. I welded in because I didn't wanna drill that many holes... plus the bed has to be removed to bolt it to the top of the frame.
I sketched up and dimensioned the axle saddles and shock relocation brackets if ya wanna build your own. Visit my build thread... the Low-Buck Bumpside for details, installation pics, shock applications, etc. Airbagit.com also offers a system at about haalf the price less shocks and shock brackets.
Btw, Fatman's netted 5.5 inches of drop.
Old Mar 2, 2016 | 11:15 PM
trozei's Avatar
trozei
I'm on mobile so I can't post the picture right now but with the factory bump stops in place you'll have 3/4" of travel which is obviously not very much. The bump stops are ~2" tall though so you can take those out. Install some stiff shocks and you'll be fine. If you want to do it right though, notch the frame.
Old Mar 3, 2016 | 08:54 AM
ru67's Avatar
ru67
Thanks . very helpful information and pictures .
Old Mar 3, 2016 | 03:46 PM
DLW-70-F100's Avatar
DLW-70-F100
I didn't notch either, I have about 3 inches of clearance with some shorter bump stops. So far, I don't notice hitting the bumps, I can see how far the shocks get compressed. It would get tricky with a load though, probably hit the bumps with some moderate weight. Not sure why there is such a big delta between trozei and mine though, I got about 1-1.5 " more clearance with the shorter bumps, but definitely not 2+ inches. I'll guess that our spring sag is different. But like said, a notch would be the proper way.
Old Mar 4, 2016 | 06:13 AM
trozei's Avatar
trozei
You installed shorter bump stops. I was saying you'd get ~2" more clearance by removing them entirely.
I know for a fact that with the factory stops the clearance is 3/4" but I have not measured the length of the stops. My box is off right now so I could do that next time I'm at the shop.
Old Mar 4, 2016 | 09:14 AM
DLW-70-F100
I understood what you said, I had 1.5" clearance with stock bumps, not 3/4". I was just saying yours is different than mine for some reason, whether saggy springs or other. No big deal either way.
Old Mar 4, 2016 | 11:26 AM
trozei's Avatar
trozei
Ahh. My mistake. I'm not sure what to tell you there.
Walkenvol
Jan 30, 2019 10:15 PM
ibleedblue1385
Offroad & 4x4
58
May 2, 2011 01:24 AM
dotcentral
Sep 20, 2005 05:33 PM
Sixoh
Mar 22, 2004 11:03 AM
DJ Rosa
39
Mar 12, 2003 12:47 PM
