induction tachometer?
Old Mar 3, 2016 | 06:30 PM
eakermeld's Avatar
eakermeld
Yes it comes out in one piece. Crawl under the truck and give the cable some slack there so you don't tear anything up at the cluster.
Old Mar 3, 2016 | 06:38 PM
Eddiec1564's Avatar
Eddiec1564
Once you have the speedo cable unhooked(a job in it's own...... stupid clip) you will get little more slack in the wire harness. Just watch out when you unplug the harness so the contacts will not break off.
Any 87 to 91 F-series and Bronco cluster will work.
Old Mar 3, 2016 | 07:35 PM
scrobbie's Avatar
scrobbie
I thought so! And yes i know about the old speedometer cable and getting enough slack to unhook it it was easier to me to get enough slack out of it! The pain to me was when i had to put the cluster back in! But i had to remove the cluster to lube the speedometer cable it was chirping! It drove me insane when I drove it!! Lol I just hope i can find one! I only have 4 u yank it yards by me and 3 of them are pick n pull but they are not that far apart. Thanks again you guys for the help!!!! Greatly appreciated!!!!
Old Mar 4, 2016 | 11:29 AM
scrobbie's Avatar
scrobbie
Hello again all u wasn't able to find a gauge cluster with a tachometer for my 88 oh well i guess I'll just have to deal with what i got for now. Thanks for all input and ideas!!!!!! Will let u know if i ever find one! Thanks again
Old Mar 4, 2016 | 08:13 PM
eakermeld's Avatar
eakermeld
1989 Ford F150 Lariat XLT Instrument Panel Cluster Gauge 87 88 89 90 91 Bronco | eBay
Here's one right here.
Old Mar 4, 2016 | 08:42 PM
scrobbie's Avatar
scrobbie
Yes i saw that one unfortunately that one is a bit out of my price range at this point in time but thank u for looking it up though!! I got bigger fish to fry also i just did a code check on my truck and got codes: 84 41 and 33 aaaahhhh! Lol so i got to work on that now not good!! Thanks again I appreciate it! So much man
Old Mar 4, 2016 | 09:09 PM
eakermeld's Avatar
eakermeld
Those codes might not be as bad as you think. A vacuum hose off/broken at the EGR will get you those codes.
Old Mar 4, 2016 | 09:39 PM
scrobbie's Avatar
scrobbie
true but code 41 is lean on the left side which could be the o2 sensor or maybe intake leak hope not?
Old Mar 4, 2016 | 09:47 PM
eakermeld's Avatar
eakermeld
Vacuum leak will throw a lean code. If you are getting fresh air somewhere you are not supposed to and it isn't measured by the computer.......... guess what, you are lean.
Old Mar 4, 2016 | 10:06 PM
scrobbie's Avatar
scrobbie
Yeah i haven't found any vacuum leaks yet and i just replaced all the plastic ones except the map sensor and the ones that go just above the blower motor passenger side up by that, actuator thats on top of the blower motor
Old Mar 5, 2016 | 10:04 AM
Redcat Diesel's Avatar
Redcat Diesel
I just found this thread and I'm hoping someone here may be able to help with my tach issue. I have a 96 F150 with a 300 efi. I want to install a tach and while I'm aware that factory units are plug and play I'd rather use the aftermarket one I already have. My question is where can I tie it into the ignition ? I know the old trucks went to the negative side of the coil like the tach instructions tell me but I'm not sure on an efi with obdII and I don't want to accidently fry something.
Old Mar 5, 2016 | 10:29 AM
scrobbie's Avatar
scrobbie
Im not really sure my friend im new to all this still unfortunately I ask for more help than i can give! But I know there are others here that can help! Sorry man!!
FLJ
Electrical Systems/Wiring
May 30, 2009 04:01 AM
cobrasjj
Jan 28, 2008 07:44 AM
khadma
1997 - 2003 F150
Jul 14, 2007 07:11 AM
Duder
1983 - 2012 Ranger & B-Series
15
Nov 28, 2004 04:25 PM
88blkranger
Aug 6, 2004 10:49 AM
