elec. problems.
Old Feb 28, 2016 | 02:46 PM
Kevinmccormick's Avatar
Kevinmccormick
elec. problems.
I have a 99 f350 7.3l 4x4 and my battery light flickers randomly. I have checked the altinator and both battery's. All brand new and seems to be ok. They only are getting a charge when the battery light is flickering. I put both new batteries in on Thursday and on Sunday I needed a jump at the store. And suggestions?
Old Feb 28, 2016 | 03:21 PM
crop harvester's Avatar
crop harvester
You could start with monitoring voltage with volt meter,check battery connections,ground connections on engine block & chassis,check plugin on alternator for bad connection.
Old Feb 28, 2016 | 03:22 PM
Xcelor8's Avatar
Xcelor8
Yup bad alternator, just because its new/newer doesn't mean anything, mine replacement for the original lasted a year, and I had a lifetime warranty. Same exact symptoms.
Old Feb 28, 2016 | 03:23 PM
Xcelor8's Avatar
Xcelor8
If you pull it out the shop should be able to test it on the spot.
Old Feb 28, 2016 | 03:44 PM
Kevinmccormick
I have had 4 altinator on 2 years and 4 batteries.
Old Feb 28, 2016 | 10:28 PM
bigb56's Avatar
bigb56
I have not heard a lot of good about box store alternators. I am planning to get a spare but I want it to be a good one. Thinking of going to the dealer, or getting the Bosch 6.0 one from Amazon and making it fit.
Old Feb 29, 2016 | 05:27 PM
Hitagain's Avatar
Hitagain
Could be bad battery cables, I was eating batteries every year, replace my ground cables and problem is gone.
Old Feb 29, 2016 | 06:09 PM
Sous's Avatar
Sous
FTE Leadership Emeritus
FTE Emeritus
Check the grounds to the engine, they are easy to get to and clean, I just did mine this weekend. There is also one smaller ground wire off the passenger side battery that goes to the inner side of the fender.
FL SuperDuty
Mar 24, 2018 02:30 PM
KHflatbed
May 31, 2017 10:18 AM
fordtruckrodder
May 24, 2013 06:30 PM
WMDPSD
51
Jan 3, 2009 06:30 PM
live2hunt
Aug 30, 2007 11:31 PM
