Will this cause a HPO leak?
I am at my whits end with this. I tore this standpipe out the other night by mistake (I was drinking a fair amount).... I was planning on pulling the dummy plugs as those leak more often, but when I saw this, I got excited. It looks like the teflon ring may be pushing the o-ring and making it leak? I hope to God this may be the end of my troubles... Please advise
Fixed
i did fix this... it was none of the above problems. I had a few leaking injectors. I changed the oil and got almost 20 qts out. Mechanic said this was normal. Ran great for a while and the. Problem started again... new machine said to get the oil tested. Came back with catastrophic levels of diesel in the oil. The diesel was thinning out the oil so bad that the oil wasn't seating the seals. Changed all 8 injectors and truck runs good so far for the last 5k miles
Prepare for turbo bearing issues in the future.
Rocking M
12-29-2003 09:51 PM
