2000 PDS 4x4 Turbo connection to MAP Senor
I am doing so maintenance on my truck, after I had a hole punctured in the driver side innercooler pipe and because I am loosing boost I checking every think that is attached to the turbo. I have come to the Map sensor line and see that the Part on the turbo that you plug the line into is just sled in there. and really no seal unless I am missing something. and the part moves up and down really easy which I think can cause a boost leak. y ideas on sealing this elbow up or does it not need to be. I have attached a picture to show what I am talking about. Thanks
diesel-fitter-bum01
09-08-2010 11:20 AM
