low turbo boost
Old Jul 24, 2011 | 09:19 PM
seth1's Avatar
seth1
low turbo boost
i was driving my truck today 03 6.0 162k, and noticed when i punched it down the boost would not go over 15psi. not sure what would cause this if the turbo just needs a cleaning or a sensor. any ideas? thanks
Old Jul 24, 2011 | 10:25 PM
BLADE35's Avatar
BLADE35
you may need to clean the turbo, EBP sensor,MAP sensors
also check the CAC boots and Tube if you have the plastic one on the driver side for leaks
also check the up pipes behind the moter that go to turbo ypipe at the flex joints
mikec91
Feb 4, 2013 08:26 PM
pbgsho2
Jul 25, 2011 06:25 PM
diesel-fitter-bum01
Sep 8, 2010 11:20 AM
go6.0go
Feb 2, 2009 09:47 AM
Ben Alston
Oct 12, 2004 07:04 AM
