more glow plug problems
Old Feb 25, 2016 | 06:26 AM
dpoe1962's Avatar
dpoe1962
glow plug malfunction
I have a problem on my 1994 7.3 IDI, previously, the wait to start light didn`t work, and the controller clicked, after replacing the glow plugs, everything worked as it should, wait to start light came on, warmed the plugs ,and started great, after about 2 weeks, back to the same, no wait to start light , and clicking controller, I retested all of the plugs with test light , and they read good, any help would be appreciated thanks
Old Feb 25, 2016 | 07:41 AM
fuzzy1626's Avatar
fuzzy1626
Originally Posted by dpoe1962
I have a similar problem on my 1994 7.3 IDI, previously, the wait to start light didn`t work, and the controller clicked, after replacing the glow plugs, everything worked as it should, wait to start light came on, warmed the plugs ,and started great, after about 2 weeks, back to the same, no wait to start light , and clicking controller, I retested all of the plugs with test light , and they read good, any help would be appreciated thanks
What glow plugs did you use?
Old Feb 25, 2016 | 09:59 AM
tjc transport's Avatar
tjc transport
i ain't rite
welcome to FTE. as said above, what glow plugs did you use?
it sounds to me like you used something other than motorcraft ZD-9 plugs, and they burned out.
Old Feb 25, 2016 | 04:31 PM
444dieselrod's Avatar
444dieselrod
Testing with a test light will only tell you if there open or shorted. A shorted GP will make the controlled kick in and out due to high current draw. You need to use a multimeter to ohm the plugs. Once that is done we can move on to possibly more problems if they exist.
jstoddard
Feb 5, 2020 01:00 AM
1984_IH6.9_Project
Jun 13, 2016 09:19 PM
trakman
Jan 31, 2011 09:23 PM
iron1951
May 16, 2010 08:50 PM
mrmilkme
Dec 26, 2009 03:19 PM
