Glow plug help?
Old Jun 13, 2016 | 02:45 PM
1984_IH6.9_Project's Avatar
1984_IH6.9_Project
Glow plug help?
I'm working on re building a 1984 6.9L IDI and I just put new glow plugs in and it was starting fine but now it's having trouble I looked at the plug that goes in the controller and it's missing one of the 6 metal pieces is there anyway I can replace it or what else could be my problem
Thanks for any help
Old Jun 13, 2016 | 04:09 PM
genscripter's Avatar
genscripter
Did you use motorcraft plugs? If not, then get those cheapos out IMMEDIATELY before they swell. There is a thread on this forum that explains how to remove swelled Autolite plugs.
Old Jun 13, 2016 | 04:41 PM
1984_IH6.9_Project
I used genuine motocraft ZD-1 glow plugs
Old Jun 13, 2016 | 04:43 PM
tjc transport's Avatar
tjc transport
i ain't rite
first step is to install a small light bulb in the cab in line with the glow plugs to see if they are getting power or not. i do not trust the wait to start light.
Old Jun 13, 2016 | 05:06 PM
1984_IH6.9_Project
They get power and I have a new relay solenoid that I just put in (it was setting in a field for 5 years before I started working on it that might be part of the problem)
Old Jun 13, 2016 | 05:22 PM
tjc transport
i ain't rite
if you are positive the glow plugs are getting power and it does not start, either A: the new glow plugs are bad. (very doubtful)
or B: the problem is fuel related and not glow plug related. (more likely)
Old Jun 13, 2016 | 05:57 PM
genscripter
I second that.
To the OP, why did you think the starting problem was GP related?
Old Jun 13, 2016 | 06:13 PM
madpogue's Avatar
madpogue
'84 does not have a WTS light. The GP light is wired directly to the switched side of the contact circuit of the relay, so it is in effect "in line" (well, in parallel, actually) with the GPs.
Old Jun 13, 2016 | 09:19 PM
1984_IH6.9_Project
I second that.
When it's warmed up and the motor is still hot it will start but when it's been setting and cold it won't start and when it finally starts you can see a large cloud of smoke come out my exhaust. Also I had it starting on its own for about 2 weeks and the first time it was The glow plugs they were all bad and had been used when they were shot
jstoddard
Feb 5, 2020 01:00 AM
f250d4x4
Jan 16, 2012 07:06 PM
cstronko
Jan 4, 2009 02:03 PM
jmaines
Jan 13, 2008 01:33 PM
Ace of Spades
Aug 8, 2004 01:29 AM
