how do you tell??
Old Dec 23, 2009 | 07:25 PM
mrmilkme's Avatar
mrmilkme
how do you tell??
hi all , on my 84f250, how do i tell if the glow plugs are working?? when i turn it on the light stays on a bit and it starts , but how do i know if the 1 or 2 , glow plugs are not working? i use it for plowing on the farm so it is plugged in when its cold, so that is helping i am sure , i was just wondering. thanks and have a SAFE and happy xmas
Old Dec 23, 2009 | 07:54 PM
Knox's Avatar
Knox
you could take them out and test them
how long is the glow plug light on?
Old Dec 23, 2009 | 07:57 PM
87crewdually's Avatar
87crewdually
Start with skimming through the 2 posts at the TOP that say READ FIRST: Glow plugs. If your truck is 87-up go here: https://www.ford-trucks.com/forums/9...le-system.html
Old Dec 23, 2009 | 08:37 PM
mrmilkme's Avatar
mrmilkme
ya i went through the read first posts, but it seemed all thay talked about was what brand too buy,thanks,, the light stays on about 5-7 sec,
Old Dec 23, 2009 | 09:22 PM
Links56's Avatar
Links56
Don't worry about it until it quits coming on or won't start. If you have it plugged in anyways. Otherwise you have to test them with an ohm meter individually.
Old Dec 23, 2009 | 11:35 PM
johnboggs21's Avatar
johnboggs21
hook a test light up to the positive battery terminal and touch the top of each of the plugs with the tester. Make sure to remove the connectors first. If the tester lights, the plug is good.
Old Dec 23, 2009 | 11:51 PM
starmilt's Avatar
starmilt
This doesn't really tell if it is good but if it doesn't light it is bad.
You can test them with a ohmmeter but it has to be capable of reading .5 ohms and a lot of them will not.
Old Dec 24, 2009 | 11:11 AM
87crewdually
Correct and so many make the assumption if the light lights it's gotta be good. That's the difference between static and dynamic testing.
Old Dec 24, 2009 | 11:37 AM
johnboggs21
IF the test light lights, then chances are that the plug is good.
Old Dec 24, 2009 | 04:39 PM
Dave Sponaugle's Avatar
Dave Sponaugle
The 84 glow plug system don't care if the glow plugs are burnt out or not.
It uses coolant temp and a timer to heat the glow plugs.
So the only test is either the ohm test or the test light test, with the ohm test being the most accurate.
Old Dec 26, 2009 | 03:19 PM
Marianna2003's Avatar
Marianna2003
If you have a battery charger with a meter, you could disconnect the GPs and power them up with it. If they draw 10 amps or more, they're good. If not, they're bad.
mrsvegan
17
Oct 19, 2013 07:26 PM
mabc926
Aug 28, 2010 12:51 AM
marks500
13
Oct 21, 2008 10:46 PM
powerglyde1234
Nov 7, 2005 10:31 PM
sexwax
31
Feb 14, 2004 01:47 PM
