Pinion seal
Old Feb 24, 2016 | 05:09 PM
bradphx's Avatar
bradphx
Pinion seal
Has anyone replaced the rear pinion seal on a 9 inch?
Old Feb 24, 2016 | 05:56 PM
ultraranger's Avatar
ultraranger
Replacing a Leaky 9-inch Pinion Seal
https://www.ford-trucks.com/forums/1...l#post15574773
Old Feb 24, 2016 | 10:01 PM
mark a.'s Avatar
mark a.
Make sure you check the vent tube. Sometimes they can get clogged and seals will start leaking.
Old Feb 25, 2016 | 08:25 AM
bradphx's Avatar
bradphx
Ok so here's what's up. On Valentine's Day I dropped the driveline. I removed the yoke. Then I pulled the seal out and replaced it. I put everything back together. When I was pulling the seal I did slip with a chisel and nick the ring around the seal on the pinion support. I didn't think it was that bad but now it went from a slower leak to a persistent dripping. I've tracked down a new/used pinion support. Any ideas other than that?
Old Feb 25, 2016 | 11:00 AM
78 PEB's Avatar
78 PEB
Install another new seal. Use some good old #2 Permatex around the outside perimeter of the new seal. That should take care of your problem unless the gouge is really deep. If so, you may need to find another bearing support.
Powerstoke73
Aug 16, 2014 07:54 AM
miottimouse
Aug 21, 2013 11:08 PM
ranstl
2004 - 2008 F150
Jun 1, 2010 09:40 PM
61 uni
16
Mar 13, 2009 05:42 PM
buckshot047
Apr 3, 2007 04:10 PM
