Help Identify These Brackets/Mounts
Old Feb 24, 2016 | 08:27 PM
RayoVac's Avatar
RayoVac
Does anyone know what these brackets/mounts are for (I have two)? I just bought a 79 F350 with a 400m and got a whole slew of extra pieces parts. I have identified most of what I have, but these two brackets are alluding me.
Thanks in advance,
Rayo
Old Feb 24, 2016 | 08:46 PM
HIO Silver's Avatar
HIO Silver
Interesting... dunno what they are but I'd start looking for two bolt holes roughly six inches apart.
Note the elongated holes. That would lead me to concluded that there was some adjustability designed into the brackets.
tabascom16's Avatar
tabascom16
They are bottom braces to the transmission cross member. They will bolt to the cross member and the frame rails.
Old Feb 24, 2016 | 08:47 PM
OldOrange's Avatar
OldOrange
I believe those are the side support mounts for your transmission crossmember. Your crossmember has two bolt holes on either side that fasten at the inside top of the frame. Then these brackets bolt to the sides of the crossmember with two bolts per side. and attach at the bottom of the frame with two more bolts per side.
Old Feb 24, 2016 | 11:35 PM
77&79F250's Avatar
77&79F250
Moderator & parts slinger
X3 on that.
Old Feb 25, 2016 | 09:49 AM
RayoVac's Avatar
RayoVac
Thanks guys, that is exactly what they are and where they were NOT??? Are these optional for some reason, I can see that big cross member is bolted up higher where it meets the top side of the frame. Would there be some reason not to install these lower supports or was it an oversight by the previous owner?
Old Feb 25, 2016 | 11:34 AM
77&79F250's Avatar
77&79F250
Forgot, lazy, to busy, figured it did not need them.
menzfamfour
1978 - 1996 Big Bronco
Apr 29, 2008 11:11 AM
Nedcampion
Mar 27, 2007 04:49 PM
six7seta
Mar 2, 2005 12:09 AM
88treadbrite_150_4spd
Dec 8, 2003 09:48 AM
Greywolf
Apr 24, 2002 06:19 PM
