Hands Free Phone Static
Old Feb 23, 2016 | 08:53 PM
TexasGuy001's Avatar
TexasGuy001
I have a Pioneer head unit and am using this iSimple hands free calling AUX cable for my Samsung phone. It seems to work well and I have no static on my end, but the person I am talking to has tons of static. I believe it is alternator noise. They say it increases with speed or throttle. Has anyone else experienced a similar issue?
iSimple CallJax 3.5mm Audio Cable Black ISMJ33 - Best Buy
Old Feb 23, 2016 | 09:41 PM
rla2005's Avatar
rla2005
Verify the radio suppression capacitor on the coil is still connected. If it is, check it with a meter than can measure capacitance.
Old Feb 24, 2016 | 02:13 PM
TexasGuy001
I'll look at it an measure it. Do you know what the value should be?
Old Feb 24, 2016 | 08:20 PM
TexasGuy001
Well, unfortunately neither our Fluke or Radio Shack meter are able to measure capacitance.
Old Feb 24, 2016 | 08:37 PM
Lead Head's Avatar
Lead Head
Ignition interference is usually a rhythmic popping right in time with ignition pulses, right?
Alternator noise is usually a high-frequency squeal that changes with engine speed.
Old Feb 24, 2016 | 09:16 PM
danr1's Avatar
danr1
Your phone and stereo, both of them do not offer Bluetooth connection?
Old Feb 25, 2016 | 12:43 AM
TexasGuy001
The phone does, but the stereo does not have that feature.
I checked ohms on the capacitor. One way reads 11 ohms and reversing the leads reads 76 ohms.
Old Feb 25, 2016 | 05:59 AM
rla2005's Avatar
rla2005
Good question. I do not have a vehicle with distributor ignition anymore to check.
Old Feb 25, 2016 | 06:00 AM
rla2005's Avatar
rla2005
Capacitors are rated in farads, ohms are of no value here.
Old Feb 25, 2016 | 05:13 PM
TexasGuy001
I was told by an electrical engineer and an electrical technician that you can test a capacitor this way. I've been trying to find a friend with a meter than can measure capacitance and nobody seems to have one.
Old Feb 25, 2016 | 05:16 PM
TexasGuy001
Anyway, I guess I'll try replacing it. I don't seem to be able to find one at the parts store etc.
Old Feb 25, 2016 | 05:51 PM
danr1's Avatar
danr1
See,
https://www.ifixit.com/Wiki/Troubles...ard_components
rla2005's Avatar
rla2005
Unplug the capacitor, see if it gets any worse. You could also try getting a reasonable 100-200 uFd capacitor rated for something above 12VDC (40V is common) then use some jumper leads to see if the noise goes away.
I did find a Ford part number: F6UZ-18832-AA
Not Fragile
31
Jan 21, 2022 09:05 AM
galaxie641
1983 - 2012 Ranger & B-Series
Sep 11, 2013 02:49 AM
alvald83
Jun 17, 2010 03:52 PM
GloveGuy
Electrical Systems/Wiring
Aug 29, 2009 11:25 PM
Jigsaw
May 28, 2003 09:33 PM
