Radio Capacitor - 1966
I am refering to a noise surpressor. Old trucks had these capacitors sometimes by the voltage regulator, next to the ignition coil and even on the antenae lead-in. My truck, which did not come from the factory with a radio, does not have any of these.
That could be why my radio plays so poorly! Help!
Hello Jigsaw!
I had a similar problem with a '63. Radio Shack
or JCWhitney has the noise supressors that
install in-line to the radio's hot wire. Not OEM
but definitely a HUGE improvement with no
electrical whine on acceleration.
Good luck with it!
White_knight
Good luck with it!
White_knight
Thanks. I remember years ago seeing (on other vehicles) a capacitor near the voltage regulator and another by the ignition coil. I was told that they were to prevent radio interference. Nowadays, all that stuff is built in - whether you have a radio or not! I will try Radio Shack. Thanks again.
Hey Jigsaw
I'm surprised to find someone that still
listens to AM. I still do- and not just for
news/talk. My truck "Wilma" has her AM
still in its original location, one speaker,
and working like it was meant to. The
FM/cass./CD and XM are in the glovebox.
The reason why? Nobody wants to
change stations on the old AM and the
glovebox is locked.
I would say this arrangement is so that
the truck maintains a stock appearance
but you probably guessed different.
See you in the posts!
white_knight
glovebox is locked.
white_knight
