Wiring Harness Question?
I have replaced the radiator support and now am in the process of
hooking all the wiring harnesses up correctly
My question is I have two male and female wiring plugs
on the left side of truck at the voltage regulator area
one only has two wires going in and two wire coming out
same color code in and out looks to go the hot side of the starter
solenoid mounted on right side of the right fender.
Is that correct?
My other question is the other plug has 3 wires going in
and only 2 coming out going to the left front turn signal and
parking light
Does those plug into each other?
The wiring diagram I bought is not clear
Sorry for asking the question I should have tagged them when
I took it apart
