T98 shifter question
Old Feb 27, 2012 | 01:48 AM
66crawler's Avatar
66crawler
My shifter seems to be all over the place lol, in gear its fine but the 2-3 shift is tricky and grinds sometimes if I don't get it perfect. Reverse can also be tough to get to. Is the shifter supposed to rotate? And what can I replace to tighten it up?
Old Feb 27, 2012 | 05:28 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
T-98 shifter problem.
The shift lever retainer cap (8MTH-7220) threads on/off.
When the cap is removed, a roll pin is visible within the threads of the shift tower...it's used to retain the shift lever in place.
If the roll pin is MIA, the lever flops around.
Old Feb 27, 2012 | 10:53 AM
killerkjn's Avatar
killerkjn
I had the same problem on my t98. My shifter was real sloppy. when I unscrewed the retaining cap my roll pin had augered out the slot on my shifter. The way I fixed it was I filed the slot in my shifter so the sides are straight. Then took a hardend drill bit the exact size of the slot (so it just fits in slot). then reamed out the hole in the threaded part of transmission top the exact size of the drill bit. Then I made a roll pin from the shank of the drill bit to the length needed. I put it all together and the shifter works great.
Old Feb 27, 2012 | 11:35 AM
66crawler's Avatar
66crawler
Thanks guys ill check it out, shouldn't be too hard with no boot on it lol
Old Feb 27, 2012 | 04:46 PM
66crawler's Avatar
66crawler
Well I checked it out and it looks like that's what I'm going to have to do killerkjn. The pin was there but real loose and looks like a home made pin, the slot on the handle isn't in to bad of shape but I'm going to have to do something before it gets really beat up lol.
Old Feb 27, 2012 | 04:54 PM
NumberDummy
COTT-7B125-B .. Trunnion (roll pin) retains shift lever / 5/8" long / 1/4" O.D. / 1960/64 T-98 / 1965/71 T-18.
Closest sources to SoCal:
ROBINSON FORD SALES in Calexico CA has TWO = 760-357-3141.
PARTS INTERNATIONAL in Farmers Branch TX has FIFTY = 888-727-0418.
Old Feb 27, 2012 | 05:28 PM
66crawler's Avatar
66crawler
I'm in so cal now, have to change my info lol thanks nd
Old Feb 27, 2012 | 05:33 PM
NumberDummy
Edited post now says closest sources to SoCal. My bad, I know you're in SoCal since we just spoke on the phone.
Old Feb 27, 2012 | 05:48 PM
66crawler's Avatar
66crawler
No worries, ill have to drill it out and use a bigger pin anyhow, thanks again nd.
Old Feb 22, 2016 | 04:24 PM
New64's Avatar
New64
Additional part numbers.
Hi NumberDummy, I was hoping you had a part number for the spring inside the emergency brake handle.
And also, if I have replaced my Trunnion pin and I still have a lot of play, what else should I look at? Thanks for any help.
leasesvc
Dec 27, 2020 11:10 AM
webstar61
Oct 31, 2012 08:15 PM
ericford1984
Apr 20, 2012 05:50 PM
jcuellar
Feb 6, 2008 07:47 AM
Bigern822
Feb 8, 2003 01:46 AM
