OLD OLD OLD CL posts
Old Feb 10, 2016 | 02:28 PM
  #256
Skip1970's Avatar
Skip1970
geez speakers on roof rack?
Old Feb 10, 2016 | 02:46 PM
  #257
NewXer's Avatar
NewXer
Originally Posted by 05MilMachine
Ford Excursion Yet
Ford Excursion Yeti
The Yeti conversion?
That would make an awesome shooting platform? Even got the ladder.
Old Feb 10, 2016 | 09:23 PM
  #258
Mikpsdad's Avatar
Mikpsdad
Any of you guys in Georgia? More harley wheels.
https://atlanta.craigslist.org/nat/wto/5428135724.html
Old Feb 10, 2016 | 10:30 PM
  #259
Skip1970's Avatar
Skip1970
why are there so many getting sold are they cracking? crackalacka badda bing
Old Feb 11, 2016 | 11:34 AM
  #260
Country_Mouse's Avatar
Country_Mouse
More Harley wheels. No price, said to make offer. Why are these so desirable? Educate me. Just the look?
http://orangecounty.craigslist.org/wto/5443043743.html
Old Feb 11, 2016 | 11:39 AM
  #261
DidieX's Avatar
DidieX
Those are the 05 and up style, they need expensive spacers to properly fit the Ex. The reason they are so desirable is it was the only style made by Ford that bigger then the stock 16". They did make 2 very similar styles, I think for the Lariat and another trim level, but it's basically the same as the Harley version with some very slight differences in the detailing and finish. The Harley version is the easiest of the 3 to find.
  #262
Mikpsdad's Avatar
Mikpsdad
99-2016 FORD F250 f350 HARLEY DAVIDSON WHEELS AND TIRES
Those will need spacers. 2004 was the one year ford made an 18 inch wheel that will fit out excursion. King ranch painted. Lariat shiny. Svt awesome. And harley bling versions.
Old Feb 11, 2016 | 01:19 PM
  #263
PSUhoss's Avatar
PSUhoss
Do these look familiar to anyone? Thoughts?
Ford v10 headers
V10 headers $250
Old Feb 11, 2016 | 02:19 PM
  #264
RobRoss's Avatar
RobRoss
If I ever move to headers, I'd go with ones that get rid of the crummy factory Y pipe.
Old Feb 11, 2016 | 02:31 PM
  #265
Apocalypse's Avatar
Apocalypse
You couldn't pay me to swap to those shorties!
Old Feb 11, 2016 | 03:27 PM
  #266
IMASAP's Avatar
IMASAP
Whats with the tires ? Looks like they sawzalled the tires off but left the beads ?
Old Feb 11, 2016 | 03:28 PM
  #267
Skip1970's Avatar
Skip1970
must not have had a tire machine.
Old Feb 11, 2016 | 04:29 PM
  #268
05MilMachine's Avatar
05MilMachine
I got my matching spare from a guy who cut the tire off. Thankfully he didn't try to cut further since he was going to scrap them for aluminum! Maybe those wheels are being saved a nasty fate...
Old Feb 11, 2016 | 07:05 PM
  #269
WE3ZS's Avatar
WE3ZS
The above linked to rims are '05+ and would need spacers to fit our EXs.
Some of this was already covered but here goes anyway....
18" rims are considered an upgrade (by some or most....) because they let you either reduce the tire side wall height (if keeping the same height tires) or retaining similar side wall height as stock (if mounting taller tires). Taller tire side walls can lead to more sideways deflection and poorer handling, conversely shorter side walls typically reduce deflection and provide for better handling. In a case like my setup I wanted to run 35" tires (I feel they are just the "right" size for the scale of the body) but with my heavy towing duties I did not want to increase the sidewall height very much (like a 35" tire on a 16" rims would have) to maintain good road manners with the high rear axle weights and trailer induced sideward movements. So going with the OEM '04 18" Lariat rims allowed me to keep almost the same side wall height (+.89" in my case) as stock and still get the full 35" tire height I wanted.
When Ford changed the pickup trucks 4X4 suspensions over to coil springs instead of leaves like all EXs have in '05 they also changes the wheel mating surfaces to a wider stance. The sheet metal didn't change so to keep the tires in the same place under the trucks as pre-change the new rim back spacing was changed. All Super Duty trucks from '05 on run the new back spacing, all SDs and EX prior to then use the "old" spec backspacing. There is approximately 1.75" difference between the two. Mounting the "newer" rims on an "older" EX (or pickup) will have the tires sitting that same 1.75" farther in towards the center of the truck and make front spring rub more of an problem. The best way to make these newer rims work is with the use of 2" hubcentric spacers, they can cost more than a decent set of late model take-off rims and tires. The little extra spacer thickness makes it so you don't have to trim the stock lug studs down, like you would if the spacers were only the needed 1.75" thick.
Just before the SD suspension change in '05 Ford made a series of 18" rims for the pickups, since these trucks have the same suspension geometry as our EXs those rims fit our wagons perfectly without the need for spacers. This series of 18" was the ONLY plus sized (over 16") rim offered by Ford and all 4 versions share the same basic wide 5 spoke design with some finish and detail differences.
Harley Davidson, the most common as they were standard on all '04 H-D F-250/F-350 trucks for the entire model year. Highly polished with the H-D shield logo on one spoke and small ridges milled into the rim inside the spoke pockets. These rims also used unique to them special chrome closed end lug nuts and special center caps that left the nuts exposed.
King Ranch, Next most common as they became standard on KR trucks at mid-year '04 but could be optioned out of for the 16"s. These are polished with tan or gold painted spoke pockets. Center caps look just like the standard caps with the KR logo script.
Lariat, Only available as an option on Lariat trucks starting mid-year '04 in place of the standard 16" rims. These look just like the KR version except the spoke pockets are painted silver that closely matches the polished aluminum finish. Used the standard center caps.
SVT, Very rare, these were only available over the counter from Ford Performance dealers parts departments, they did not come on any trucks from the factory. Polished finish with blocky details on the rim inside the spoke pockets and milled slots on the rim end of the spokes. Used a special smooth round cap with no markings.
All the versions can be used with the standard chrome or black center caps and regular SD lug nuts.
All of these rims are 18" X 8', which makes them 1" wider than our factory aluminum 16"s.
Old Feb 11, 2016 | 11:38 PM
  #270
wpnaes's Avatar
wpnaes
Thx Tom, Stewart would you add that post to our Tech folder? Helpful for those looking for the 18'' wheels without spacers.
Now, everyone should be exercising their 'rep' muscles for that post.
