Steering arm removal?
Old Feb 17, 2016 | 08:52 PM
mlandrum51F1's Avatar
mlandrum51F1
Working on power steering upgrade and removing old components. 51 f1 mostly stock with safety updates. I have the drivers side steering arm loose, but cant seem to remove it. Is there a cam or pin im not seeing? Couldnt find any reference in shop manual. Removed cotter n nut. Used air hammer gently. Pushed forward 1/2" n then stopped. Swivels vertically. Appreciate any clues.
Old Feb 18, 2016 | 05:10 PM
steve(ill)'s Avatar
steve(ill)
is it just the ball socket that is swiveling or the threaded shaft inside the arm? With the cotter and nut off, you just impact as stated until it pops loose. Could be your pickle fork tool is not thick enough and bottoming out on the shaft and not going in far enough
mlandrum51F1
May 19, 2016 10:11 AM
Corpsman24
Jul 30, 2015 06:42 AM
injun_ear
Sep 17, 2010 10:28 PM
gnwalker
Oct 7, 2007 04:22 AM
sancochojoe
Feb 17, 2004 06:40 AM
