Cant remove the Steering Gear arm
Old Feb 14, 2004 | 06:45 PM
sancochojoe's Avatar
sancochojoe
anyone know what puller the shop manual is talking about for the 51. I can't remove the steering Gear arm to save my life.
I'm trying to remove the gear box in order to remove the steering shaft, but in order to do that I need to remove the steering arm.
Is there a special puller for this???
Old Feb 14, 2004 | 07:09 PM
Fat Fendered Ford's Avatar
Fat Fendered Ford
Be sure to take the lock bolt competely out. If you loosen but do not remove it, it will keep the arm locked on the shaft. This wasn't obvious in my parts or shop manuals.
Hope this helps!
Old Feb 14, 2004 | 07:12 PM
GLR's Avatar
GLR
A pitman arm puller should do the trick....usually they are tough to pull. Good luck
Old Feb 15, 2004 | 10:06 AM
52F2's Avatar
52F2
Maybe I was lucky but I just loosened the nut on the arm and put a crow bar between frame and arm to apply pressure. Then I used a brass hammer and smacked the nut a couple of times and it came loose.
Old Feb 15, 2004 | 12:48 PM
1949fordf3's Avatar
1949fordf3
Take a look at this thread. I had the same question last
Sep.https://www.ford-trucks.com/forums/s...hreadid=154241 I used a pitman arm puller.
Old Feb 16, 2004 | 10:32 AM
48fordf1's Avatar
48fordf1
I tried a gaer puller and that didnt work at all so I just heated it up with a torch and hit it a few times with a hammer and after about ten minutes it came off.
Matt
Old Feb 16, 2004 | 09:31 PM
OilLeaks's Avatar
OilLeaks
I used a gear puller and a couple of ball peen hammers to "warm" up oposite sides of the arm around the splines and it came off without too much hassle and no busted knuckles. If you don't have a gear puller or better yet a proper pitman arm puller many of the auto parts stores will loan you one if you just put down a deposit. Really makes it much easier and you don't run the chance of ruining the part - mine was toast anyway as the ball looks more like an oval...could be where some of the wander was coming from methinks.
Old Feb 17, 2004 | 06:36 AM
sancochojoe
Yep, I got a pitman puller at Pep Boys and it came off like a snap.
Old Feb 17, 2004 | 06:40 AM
Torque1st's Avatar
Torque1st
Posting Legend
Do not apply too much heat to suspension and steering parts or you will ruin the heat treatment. Be safe!
flypfi
Aug 8, 2013 11:03 PM
ichabod40
Jun 21, 2010 09:31 PM
tonygray
15
Jul 24, 2006 09:23 PM
Snickers411
Apr 19, 2005 02:36 PM
mrdavidkendall
Dec 29, 2004 05:46 PM
