Timing Gears...
Old Feb 17, 2016 | 11:19 AM
Pkupman82's Avatar
Pkupman82
Timing Gears...
Just thinking about the last few details I need to get in order for the rebuild on my 6.9. I've been debating on replacing the timing gears while I'm in there. I did not check the backlash, but as far as wear is concerned they look fine. Would it be a smart move to replace them, or a waste of money?
Old Feb 17, 2016 | 04:38 PM
hairyboxnoogle's Avatar
hairyboxnoogle
Crossed my mind, but i wrote it off. I dunno what it is, if there is a spec for it. Do they look excessively worn?
Old Feb 17, 2016 | 08:08 PM
Macrobb's Avatar
Macrobb
I'm pretty sure they don't really wear, per se... As long as you are getting plenty of oiling, they should last a /long/ time, considering how relatively little force there is on the cam shaft, compared to the diameter of the gears.
All of the gear sets I've looked at didn't have any noticeable wear on them, so I consider it a non-issue.
Old Feb 22, 2016 | 03:39 AM
Pkupman82's Avatar
Pkupman82
I washed and cleaned them up, can't really see a good reason to replace them. I know they don't see the loads put on them, like a helical gear in a manual transmission. I guess they're going back in, no sense in spending the money if it's not completely necessary. Thanks for the input guys!
Jonathan Page
Mar 26, 2014 12:37 PM
79super460
Sep 1, 2012 09:29 PM
chrono4
Jan 26, 2005 09:51 PM
JRProaudio
Dec 16, 2003 07:42 PM
mattrlang1
Oct 10, 2002 07:35 AM
