Should I or should I not?
I have a current issue with the FICM in my 2005 6.0 SD. It is reading 43 at startup and then once truck reaches operating temp it is 47.5 - 48.5
Now for the question....I need to make a 500 mile run this weekend to pick up an enclosed trailer. Is it going to do more damage to FICM if I run it, or should I cancel the run until I get the new FICM installed. Sure don't want to ruin an injector!
What do you guys think?
To decrease risk to things, just plug the truck in for three hours prior to ignition if there is anyway at all to do that and let the truck warm up to 130 degree oil before driving it.
We can always send you a replacement FICM, pre-programmed and ready to go for arrival prior to the weekend as well if you'd didn't want to have to be worried about it.
Ed
Just don't turn the truck off as much as you can and you'll be fine. Two more cold starts on the FICM won't be significantly worse than what's already happened to it. Fill it while it's running.
I would rather make the trip with the old one and take my time testing the charging system before I waste the warranty on the new FICM with a bad alternator. Ed can't warranty a failure if your alternator is the root issue.
Ed
Nyxlee
01-26-2011 09:07 AM
bigtexan99
28
07-20-2009 12:13 PM
