1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Shimmy and shake
Old 04-07-2016, 12:36 PM
droldsmorland's Avatar
droldsmorland
droldsmorland is offline
Have the tire tech pay close attention to rim run-out as well. X and Y axis run-out. I've been chasing a vib for a while now. Factory tires were fine. At 40K Replaced with high end tires. Shop couldn't get them to balance. After a week they took them back put another brand on all was OK until about a month ago with 20K on the tires. I rotated tires now the vib is back. Re-balanced the tires...they were out quite a bit. Tire tech noticed two of the factory rims had a hop. Re-balanced again...now its worse. Taking it back in tomorrow to see what the hell can be done. May try the balance beads? The tires likely "took" to the hop wearing out in an egg shape. Im likely gonna be forced to step up to 18s or 20s now cuz Im not buying new 2 new rims $ tires. Looking for a set of new take offs as we type. GAH!! just what I need is to drop another 2K. Why are these dam trucks so sensitive to balance? I never have this problem with cars only trucks from light to heavy duty. Tractors as in Semi's arent this sensitive either.
Old 04-07-2016, 08:11 PM
BigTexRex's Avatar
BigTexRex
BigTexRex is offline
I had a very similar problem and it turned out to be my Ranch Hand Brush Guard was causing the vibration. I took it off and it was like a brand new smooth riding truck. This is after the dealer re-balanced the tires and changed the drive shaft I saw another F-350 driving down the road with a brush guard and I could see the vibration.
Old 04-08-2016, 12:19 PM
farwhitenorth's Avatar
farwhitenorth
farwhitenorth is offline
Well, that is very interesting!! Wish I had a brush guard on my truck that I could remove!!
Old 04-08-2016, 12:44 PM
fbnmark's Avatar
fbnmark
fbnmark is offline
Had shaking, vibration and almost felt like death wobble on my 2wd 04. Finally fixed with "dynabeads".
Old 04-09-2016, 01:40 PM
farwhitenorth
Picked up my truck from the dealer today. They had it for 3 full days. End result? They balanced my tires. This is the 5th time for balancing. 3 times on the old tires, 2 times on the new tires. They did not take it for any test drive. Currently it feels a little better but this is what has happened every other time. I am really contemplating my 30+ year affair with Ford.
Old 04-09-2016, 07:47 PM
Skyline Drive's Avatar
Skyline Drive
Skyline Drive is offline
You have to go beyond the dealer some 5 times.
Old 04-11-2016, 10:05 AM
countryboy73703's Avatar
countryboy73703
countryboy73703 is offline
I've having an identical issue as well with my '08 f250 6.4... driving me nuts, and I've been chasing it for a while. I just made a new thread on it before I saw this thread. On my truck it feels like there is a lump in one of my tires but there isn't. Also, I had the issue on factory wheels, as well as my aftermarket that I have on now. tire wear seems to be normal on all tires. I THINK it's coming from the back, but only because when I have my coffee or cold one in the cup holder, it about comes out of the top of the cup because it's so bad.
Old 04-11-2016, 10:38 AM
droldsmorland
Update. Its a bunch better, shall I say acceptably/tolerable. Its a 3/4 ton truck I dont expect a Cadillac ride. This is a private well known HD truck shop, where I purchased the tires. This has cost me nothing but a little time so far, but they were able to get it this time. Im still gona look for some factory take offs in the 18-20" range. FYI this has nothing to do with brand of vehicle. I've always had issues with truck balance vs auto. FYI,2 you cant use the balance beads in a rim/tire assembly which has TPS in the valve stems.
Old 04-11-2016, 10:45 AM
countryboy73703
good call on not being able to use the beads with TPMS. My situation i know for a fact is not a tire/rim issue. actually it did seem to get a tiny bit better after new tires/rim, BUT with in a couple hundred miles it was back and been there ever since.
Old 04-11-2016, 04:25 PM
droldsmorland
I've tossed wrenches professionally on big rigs in the past never had issues with them or passenger cars. Its always these trucks. Not brand specific either. However I do see the hop in the OEM 17" rim as well as the tire. But this last balance took care of 98% of it....until the next tire rotation...GAH! Any luck Ill see another 20K then Im replacing with the whole smash with 18" or 20" take offs.
redwood
1997 - 2003 F150
12-31-2013 02:39 PM
azchris
01-10-2011 09:10 AM
dvfd12
09-09-2008 09:05 PM
Wrecker
10-20-2007 09:40 PM
JoeDaddy15
16
10-16-2004 05:21 PM
Quick Reply: Shimmy and shake
