Another Shaking Vibration Question
Old Oct 20, 2007 | 08:50 PM
Wrecker's Avatar
Wrecker
I have a 96 F150 4x4 with a 5.8 and a Auto tranny. The truck is fine except between 35 and 45 mph I get a shake / Vibration. I can't tell for sure but I think it is in the front end. The tires are fair, but they will need replacing in the next few months. The part I don't understand is the truck drives fine below 35mph and over 45 mph. I can do 70 mph with no vibration and the truck drives straight as an arrow. Any suggesstions would be greatly appreciated!
Thanks
Paul
Old Oct 20, 2007 | 09:09 PM
89frankenford's Avatar
89frankenford
Lightbulb
well i would check you front end for starters. just jack the front end up and shake the tire and feel for any play in the tie-rods, ball joints, and wheel bearings. i would also get your tires balance checked. you may have knocked off a weight on one of your wheels.
Old Oct 20, 2007 | 09:13 PM
radialarm's Avatar
radialarm
When was the last time the tires were balanced? That could be it. I have mine balanced about every 4 or 5 months, or mine starts to feel rough.
Old Oct 20, 2007 | 09:20 PM
Skandocious's Avatar
Skandocious
I'm thinking this is an out of balance (or out of round) tire. Try to find a shop that has the machine that also checks for the tire for being out of round when it balances it. I had a pretty nasty vibration from out-of-round tires.
Old Oct 20, 2007 | 09:40 PM
flareside_thunder's Avatar
flareside_thunder
I've had nasty vibes from a tireswith a big dang bubble..kicker is I could only see the bubble when the tires was completely deflated and off of the rim.
