Sponsored by: Auxito
Need exhaust help
Old Feb 14, 2016 | 09:57 PM
fordboy97's Avatar
fordboy97
Need exhaust help
So I decided to redo my exhaust. (01 5.4) I deleted the rear cats and replaced them with pipe and put on a thrush chambered muffler dumped before the rear axle. Sounds nice, no check engine light. Problem is I welded the replacement pipes in with the exhaust on the truck so I couldn't get to the top of the pipes with my welder. The passenger side cat delete pipe has a huge leak that is loud while idling and also ticks at certain speeds while driving. Think I could unbolt the exhaust from my manifolds and drop it down and out enough to weld up the leak?
Old Feb 15, 2016 | 07:23 PM
steve(ill)'s Avatar
steve(ill)
some companies make at "exhaust tape" that wraps the joint to fix leaks... Life would be dependant on the temp at that point. Further away from the manifold , the better it should work.
Old Feb 16, 2016 | 01:10 AM
fordboy97's Avatar
fordboy97
Need exhaust help
Thanks for that idea, I feel like that would be a temporary fix though. When I got home from work tonight I soaked down the manifold to exhaust nuts with pb blaster while it was still hot. The drivers side look pretty easy to get to from under the truck but the passenger side look more accessible from the fenderwell. Weather permitting I'll see what I can do tomorrow
Old Feb 16, 2016 | 01:24 AM
glockholiday's Avatar
glockholiday
Exhaust tape and a good clamp like one of these from your local parts store.
HillBillyBuddha
Jun 1, 2014 11:19 PM
jbk
Apr 27, 2014 07:06 PM
parr4
13
Nov 7, 2010 08:56 PM
scottya4
Exhaust Systems
Oct 1, 2004 03:19 PM
