Sponsored by: Auxito
Please help me identify this part?
Old Feb 15, 2016 | 03:40 PM
lacyctdy's Avatar
lacyctdy
Hello,
Can someone please help me identify this part? I believe this part is causing my check engine light to continually come on, due to worn out connectors (I.e. Vacuum leak)! Thanks in advance!
Old Feb 15, 2016 | 04:19 PM
kd4gij's Avatar
kd4gij
That is your " EGR vacuum solenoid " It opens and closes the EGR valve.. What is the code you are getting?
Old Feb 15, 2016 | 04:25 PM
lacyctdy's Avatar
lacyctdy
I replaced all three O2 sensors and still getting an O2 code. Several people have told me I most likely have a vacuum leak.
What connects the EGR solenoid to the engine? Both ends are extremely worn so I want to replace the entire connector. Thanks
Old Feb 15, 2016 | 04:38 PM
lacyctdy's Avatar
lacyctdy
Isn't the EGR solenoid closer to the engine (lower portion of the picture)?
Old Feb 15, 2016 | 04:40 PM
kd4gij's Avatar
kd4gij
What year is your truck? Is that the older 5.0?
Old Feb 15, 2016 | 04:46 PM
lacyctdy's Avatar
lacyctdy
1996 F150 XLT
Old Feb 16, 2016 | 07:45 AM
Shadow351's Avatar
Shadow351
Looks like it could be the "Fuel Vapor Return Tube" Part Number F5TZ-9G271-C, I cannot find any diagrams or pictures of it so I can't say for sure. This part is discontinued from ford, so unless you find NOS you may have to go aftermarket and then who knows what it would be labeled as.
They may be able to help more in the 87-96 F150 board.
Old Feb 16, 2016 | 11:45 AM
Bluegrass 7's Avatar
Bluegrass 7
You may be misinterpreting the code and changing part that are not the problem.
What is the code/s your getting?
Good luck.
Old Feb 16, 2016 | 03:27 PM
kd4gij's Avatar
kd4gij
This is your EGR vacuum control solenoid.
CARQUEST by BWD EGR Vacuum Solenoid EGR285: Advance Auto Parts
But if you give us the codes then we can help.
CM1
Jul 29, 2008 01:07 AM
f250Bill645
Sep 29, 2007 10:03 PM
F TOO FITTY
Feb 25, 2007 10:35 PM
brassy
Jun 11, 2006 11:59 AM
ea3
1983 - 2012 Ranger & B-Series
Jul 6, 2004 09:04 AM
