PM under valve covers
Old Feb 13, 2016 | 12:40 PM
crop harvester's Avatar
crop harvester
Do these torque specs. sound right, 2001PSD 7.3,[valve cover bolts 97inlb] [glow plugs 124in lb] [rocker arm pedestal bolts 20ft lb] [injector hold down bolts 120in lb factory-125to 130 mentioned also]
Old Feb 13, 2016 | 12:50 PM
Pikachu's Avatar
Pikachu
Glow plugs: 14 ft/lbs.
Rocker cover bolts: 98 in/lbs.
Rocker pedestal bolts: 20 ft/lbs.
Injector hold down bolts: 120 in/lbs.
Old Feb 13, 2016 | 01:11 PM
jhl3's Avatar
jhl3
Pikachu is spot on.
Just make sure you use an inch pound rated torque wrench that is rated for 300 inch pounds or less instead of a foot pound torque wrench. If you use a ft/lb rated one you risk snapping bolts and that is not fun.
In other words you could use a 300 in/lb rated wrench for all of those specs but not a 100 ft/lb wrench.
Several of the guys on here will hot torque the injector hold down bolts after the initial torque while the engine is cold. Some will go to 125 in/lbs on the hot torque.
Old Feb 13, 2016 | 01:21 PM
jhl3's Avatar
jhl3
Duplicate...
Old Feb 13, 2016 | 01:42 PM
Walleye Hunter's Avatar
Walleye Hunter
Is it common to torque things like valve cover bolts? I generally only torque things like internal bolts. The others I just apply what feels right for the size bolt based on my years as a shade tree mechanic.
Old Feb 13, 2016 | 01:51 PM
crop harvester
Thanks Guys,Good tip on inch lb torque wrench,just bought one for this job,I normally hand torque valve covers,since these having wires running through them,so I will use caution
Old Feb 13, 2016 | 02:17 PM
jhl3's Avatar
jhl3
Yes. I try to torque things as much as possible, especially Injector hold down bolts and rocker arms, etc.
You can ruin the VC gaskets with too much torque but it would probably take more than 30 ft/lbs to do it.
Old Feb 13, 2016 | 02:40 PM
Pikachu's Avatar
Pikachu
I wouldn't worry too much about over torquing the valve cover bolts. The bolt holes in the gaskets have steel bushings in them to prevent crushing. The bolts do tend to stick pretty good if they're over torqued, though.
Old Feb 13, 2016 | 05:41 PM
Tugly's Avatar
Tugly
I have a variable-torque 18V impact gun. I set it on minimum torque and spin 'em on 'til she stops. Not very scientific, but it's consistent - and fast.
Old Feb 13, 2016 | 05:55 PM
jhl3's Avatar
jhl3
Exactly! I tried to be conservative at 30 ft/lbs....
Old Feb 13, 2016 | 06:14 PM
Absolute's Avatar
Absolute
The gasket won't crush, but the valve cover will warp and bend at the bolt holes. I just did my injectors and noticed how bent and warped mine were. No wonder they leaked. Never could figure out why until I spent an hour on each hammering out the bolt holes and leveling the plain. No more leak. I torque them now.
Old Feb 13, 2016 | 08:07 PM
Pikachu's Avatar
Pikachu
Well, you aren't supposed to use a 36" breaker bar either . . .
Old Feb 14, 2016 | 07:28 AM
Walleye Hunter
Yep, what he said. I use my 3/8 drive on that because that's what I need to get that back bolt so I use it all 'round. I hold my hand ooo two or three inches from the ratchet head and twist 'til they snug up, then I start in the middle of the V/C and work my way out towards the end of the V/C giving them a little more, not much. This is not a situation where they are going to vibrate loose or like an injector or piston rod where precise torque is going to be critical. So far it works fine.
diehardstroker
Oct 27, 2013 09:18 PM
dmanshane
15
Feb 26, 2012 09:01 AM
stevestroke01
Nov 2, 2011 06:40 PM
allwthrrider
Jun 9, 2011 12:26 AM
makomaker
Mar 27, 2009 11:47 AM
