The rockers are 20 ft lbs and the injector hold down bolts are 120 in lbs. I think the glow plugs are 14 ft lbs but can't swear to it. I just tighten them up good. I just tighten the valve cover gaskets. Never even bothered to look up the torque spec on those. I just go by feel.
Valve cover 8 ft lbs
Couldn't find glow plugs, anybody know the turbo two bolts tork? I wrote down 35 ft lbs but my sheet say 18 foot lbs which is correct? Thanks Chet
Ok we're getting some where 20 ftlb on rocker arms, 120 inlb on injector hold downs , 8ftlb on valve covers, and maybe 14 ftlb on the glow plugs can anyone back that up or give me a accurate answer no offense F350-6 I just like to torque everything when I go back together thanks guys
Everything seems okay to me. Just not sure on glow plugs. I asked about the turbo hold down bolts because they are bigger then say plenum bolts but the sheet only said 18 ft lbs. I'm going with 35 ft lbs. I know how hard they were coming out they had to be more then 18.
Chet
