Sponsored by: Real Truck
Which Leveling Kit?
Old Feb 13, 2016 | 08:41 AM
Pshicker's Avatar
Pshicker
Which Leveling Kit?
Hey All,
I have a 2015 F350 SCSB FX4.
I'm planning on installing a leveling kit this spring and some 33-34's on my factory aluminum 17" rims.
Which leveling kit is "correct"?
I've seen lower blocks, upper blocks, springs, etc.
suggestions?
Thanks for the input in advance!
Old Feb 13, 2016 | 09:34 AM
vermilian's Avatar
vermilian
Well I know that bilstien and ready lift both make actual springs that are 2.5" taller that will level out the truck nicely, and they usually come with longer shocks as well. Though they can be quite pricy. Either one of those sets will probably be the one going to get for my truck. Though if you go with just spring spacers, most that I've seen all go on top, plus they come with a spacer perch so you can utilize the stock spring length as well.
I know me personally I'm not fond of the "level" look especially if there is a load in the back, though I don't want a bigger lift, so once I lift the front, I'm going to replace the factory 4" block in the back with a 5" block just to keep a slight rake.
Old Feb 13, 2016 | 10:16 AM
RainDesert's Avatar
RainDesert
I was planning on a 1.5" level and F350 blocks in the rear to keep the slight rake, as I have a F250 that is almost level now. You probably don't need any lift for slightly larger tires. I run the 285/70/17's on stock and I have plenty of room. If I were to go up to the 315/70/17 I would do this lift:
Ford F250 1.5" Leveling Kit 1.5 inch
Old Feb 13, 2016 | 06:48 PM
Hotrod70d's Avatar
Hotrod70d
35" fit stock . I have ready lift 2.5 " with the 5 " block. Has all parts needed to drops way bar, pan bar, drive shaft shim. Etc paid 325 for the kit.
bryced_1
Jun 18, 2011 06:10 PM
RIsuperduty89
Apr 4, 2007 04:06 PM
edub32
Sep 4, 2006 05:14 PM
John Luther
Jun 22, 2004 06:21 PM
MClark77
Apr 26, 2004 04:01 PM
