actually the truck got us to that point in 4-high with no problem but he was in the throttle pretty heavy the whole time and once he started spinning we were done moving forward.
after that point we switched to 4-low and if he did lose traction the wheels spun much slower and didn't turn the snow into ice under the tires.
we drove the next 10 or 15 miles in 4-low at speeds between 10mph and 30mph depending on how bad the roads were.
I like to use it any time I have to use a ton of throttle to push through deep snow. keeps the wheel spin to a minimum and saves heating the transmission under heavy throttle. Aside from a little bit more mechanical noise, there is really no downside to using it.
it also works really well coming down steep logging roads. put it in 4-low, and lock the trans in a lower gear and never touch the brakes all the way down the hill.
the AWD setting, which is actually just Ford's control trac automatic 4x4. You can run it on dry pavement without issue. It engages the hubs but not the transfer case, except when it senses slippage, so once the rear spins it kicks in the front axle.
4x4 high locks it together for 50/50 TQ split.
So there's a differential inside the t-case like a old days np203?
I doubt I'll need chains, I'm running BFG KO2 tires and so far they have be great in deep snow and plow mounds and one of the trucks that is going is a trail prep raptor with a winch so I think we're good for recovery.
Oh yes, you'll need chains! Trust me. Especially going off road in deep snow and ice for more than a short distance. Chains are really helpful when it's icy and/or deep snow.
I picked up a sleeping bag rated to -50 extra blankets to line the bed and some hot packs to keep my feet warm at night.
LOL fifty below zero? I can hear the headlines at the top of the hour now "Area man suffers extreme heat stroke injury in bizarre winter camping incident, weather at 11. Stay tuned!"
I try to use 4 Hi in these trucks as much as possible. I do not like 4 Lo on these trucks in icy conditions. Anytime I have been stuck or close to it in 4lo I have found you have little control of starting stopping. It's hard to explain but compared to my older trucks, there is quite a delay when you are trying to move and jam on the brakes..... it just wants to keep on going. I had a close call on the side of a mountain last year, I felt more in control in high range.
