6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
Wrapping down pipe?
Old Feb 10, 2016 | 01:33 PM
genotac-f250's Avatar
genotac-f250
Wrapping down pipe?
Ive seen ceramic coated downpipes, stock is a dual pipe, would it be a good idea to wrap the down pipe with heat wrap tape? Installing a 4" down pipe soon and would like to get it done if it is a good idea. 6.4l powerstoke f250
Old Feb 10, 2016 | 02:29 PM
CrazySob's Avatar
CrazySob
Its not a bad idea, but its not going to gain you much. I would highly suggest getting a turbo blanket and wrapping up pipes first, but it does always help keep heat out of the motor.
We have seen a few trucks running big tunes that have seen slightly lower egts during wot runs. However there is very little change when driving around town or on the freeway. Again, the up pipes and turbo will lower under hood heat though.
Old Feb 10, 2016 | 03:12 PM
genotac-f250
Thankyou for the reply!
Old Feb 10, 2016 | 03:26 PM
CrazySob's Avatar
CrazySob
I am going to wrap my up pipes when my cab goes up for a motor build. Keeping the heat out of the engine bay is always good, I know of a few guys that have wrapped/insulated the exhaust manifolds as well... Not sure I am going to go that far, but I am interested in containing heat some. Even if it doesn't do much for performance, at least in my case.
Old Feb 10, 2016 | 03:59 PM
genotac-f250
CrazySOB, I see you have the X4. I just ordered mine from Rudy's, called them and they said PIP writes the tunes for the X4 they sell, do you have any experience with punch it? I know they make their own tuner, but wanted to go with the X4 just incase I wanted to order other tunes. Also 4 down pipe and 5" back pipes, and AFE 5r drop in filter...I'm a plastic bender so I'll be fabing something for the air box.
Old Feb 10, 2016 | 04:08 PM
CrazySob's Avatar
CrazySob
PIP has great tunes, far better than River City Diesel. I have been wanting to get a set of their tunes for a while now, just have other things to spend money on atm. I haven't driven a pip tuned 6.4 though, only Gearhead, RCD, and Spartan... Out of all of them the Spartan tunes are by far the best.
I highly suggest QuickTricks if you can get your hands on their tunes though... You will need a shop that works with them though, they no longer sell delete tunes to the general public. But Vivian writes the best tunes on the market hands down for a 6.4...
Old Feb 10, 2016 | 05:09 PM
genotac-f250
I think a local shop does their tunes, but from what I heard they are about $1K for them.
I guess I'll run the PIP and see how it goes. Thanks for the info bro!
Old Feb 10, 2016 | 05:25 PM
longview1's Avatar
longview1
Banned
I did but only cuz I had left over and easy access.
Old Feb 10, 2016 | 08:10 PM
genotac-f250
Wrapping down pipe?
Longview1, you lucky…ill be working from underneath my transmission. What up pipes are you running?
Old Feb 10, 2016 | 11:40 PM
73fan's Avatar
73fan
Would you consider yourself lucky if you had the cab off anyway because you were doing HPFP, injectors and such? Sorry, I just had to throw that out there!
Old Feb 13, 2016 | 11:52 PM
genotac-f250
Got it done! Tuned and dpf deleted, egr delete with elbow is on the way.
CRAZYSOB, I get a flash on the SCT x4 "memory leak" detected...any ideas on that?
Old Feb 14, 2016 | 02:12 PM
CrazySob's Avatar
CrazySob
Have you updated the tuner??? I got it once but never had an issue.
Old Feb 14, 2016 | 04:22 PM
genotac-f250
Yea, updated it out of the box, yesterday, first try didn't notice it, but then bumped the tune to level 3 and did it when it started.
Old Feb 14, 2016 | 06:29 PM
CrazySob's Avatar
CrazySob
Might be worth giving SCT a call and asking them. Like I said, I had it come up once but it never caused any issues. When it flashed the message I just put it back to the stock tune then retuned.
cutlass
Feb 22, 2012 01:55 PM
96 7.3
Oct 17, 2011 10:45 PM
wulfman
Dec 26, 2010 08:59 AM
wildstang
Sep 9, 2008 07:57 PM
russ&irene
Mar 6, 2006 03:02 PM
