down pipe
Old Oct 17, 2011 | 02:10 PM
96 7.3's Avatar
96 7.3
down pipe
when replacing down pipe i notice that old pipe has insulation foil around it and all the new pipes don't. will you notice heat on floor if you dont have insulation around pipe, i have been reading the new pipe replacement reduces heat. thanks
Old Oct 17, 2011 | 02:40 PM
JamesHajek's Avatar
JamesHajek
I wouldn't worry about it. I don't think you will notice anything as you are getting rid of the factory downpipe which is super restrictive and opening up the exhaust. Temps should go down.
Old Oct 17, 2011 | 02:43 PM
96 7.3's Avatar
96 7.3
thanks for the reply
Old Oct 17, 2011 | 10:45 PM
PstrokeN's Avatar
PstrokeN
also the aftermarket dp is a tight fit to i had a bad nosie vibration on the floors and it was the dp rubbing on the firewall only when i braked and turned right. so i dont think you really get that heat shield on it you have to notch or bend cut that pinch weld out
CustomBagger
Nov 7, 2013 09:06 AM
Jbru167
Mar 14, 2009 06:16 PM
ghunt
General Automotive Discussion
Jan 15, 2008 09:20 AM
Gene W
Jul 13, 2005 02:16 PM
7.3 sled
Aug 5, 2004 10:40 PM
