Mystery Machine
Old Feb 21, 2016 | 09:31 PM
  #46
scotttahoe's Avatar
scotttahoe
Originally Posted by THEDON117
always spend the money on the best parts you can buy. I bought a some u-joints a while back and replaced them and they were the ones that were destroyed, because they were not a good brand. You get what you pay for!
I couldn't agree more!
Old Feb 22, 2016 | 07:51 PM
  #47
THEDON117's Avatar
THEDON117
Originally Posted by Tugly
Here are some of the causes of vibration I have personally experienced on two of my vehicles:
  • Rust growing behind the rotors - this can cause spreading in there, making the wheels wobble a little.
  • Bent rims.
  • Driveline not balanced.
  • Bent driveline.
  • Damaged U-joints.
  • Warped rotors from siezed caliper slide pins.
  • Loose front end components.
  • Under-inflated front tires.
  • Tire imbalance.
  • Poor "automotive" front end alignment on a "truck".
  • Uneven tire wear (caused by many of the above, as well as bad shocks/springs)
It helps to know the frequency of the vibration. Half-RPM is usually combustion related, RPM can be engine/torque converter related, influenced by speed only (coasting at different speeds in neutral) can be driveline, axles, wheels, tires, brakes, etc....
Noise, Vibration, and Harshness (NVH). There are Android apps (maybe iOS as well) that can be downloaded [LINK][LINK], this would allow an Android device to record the sounds your truck makes. If you were to try this, I would suggest an external microphone attached to something hard on the truck, away from the firewall (no need to get engine noise).
So, I downloaded that app Tugly. I'm going to try it out ans see if I can pick up the metal clunking sound I've had for years now. Maybe if it picks it up you guys could help me identify what it might be. I just want to figure out what it is for sure and fix it. Then I can be done chasing these ghosts for a while.
Old Feb 23, 2016 | 06:45 AM
  #48
Tugly's Avatar
Tugly
I'd be very interested to see that thread.
loudford
Dec 30, 2010 07:36 AM
nix4x4
Apr 1, 2010 01:20 AM
RobH1965
Aug 28, 2009 06:15 PM
RTM
Mar 5, 2009 04:07 PM
GodfatherSvc
Nov 16, 2006 08:02 AM
