hp and torque #s 302 vs. 460
Mark,
Using 1984 engines as an example;
302/5.0L -
140 hp @ 3,200 rpm for the CFI unit
175 hp @ 4,400 rpm for the H.O. unit
240 ft.lbs @ 2,000 rpm for the CFI unit
265 ft.lbs @ 3,200 rpm for the H.O. unit
351W/5.8L -
180 hp @ 3,600 rpm for the V V unit
210 hp @ 4,000 rpm for the HO unit
250 ft.lbs @ 2,000 rpm for the V V unit
305 ft.lbs @ 2,800 rpm for the HO unit
460c.i. -
224 hp @ 4,400 rpm
357 ft.lbs @ 2,800 rpm
Those are all SAE NET figures from George Reid - High Performance Ford Engine Parts Interchange, publ'd 1998.
Regards,
302/5.0L -
351W/5.8L -
460c.i. -
224 hp @ 4,400 rpm
Regards,
Something tells me your van probably doesn't weigth all of 9000lbs, unless you are trying to hide alot of dumbells inside. You may instead be talking about the GVWR, alot of people confuse the two. This is printed on the doorjam, and most of the time the weight of the vehicle is unknown unless you go have it weighed. But, if your van does really weight 9k, and you tow another 10k, then a stock 460 surely isn't even enough if you want to clear hills at any more than 15-20mph. However, be very carefull if this is the case, I don't think these vans (even the older E-350) are rated to tow nearly that much.
Sorry guys, it a E-250 or maybe 350, has a pathfinder conversion, 4x4. And yes I have been on the scale (at the dump) it shocked me too. I did'nt even have half my tools in it. The 460 , when running right, did great 8 mpg, towing or not, hills and all. I have been thinking about putting a 351 in it that runs, but the more I read here, I dont know.
Superdave,
between you guys and my older brother I've decided to put the 460 back in, the problem is whitch carb to put and also joe says to get a new brain box for it ,some fancy high priced one. The engine has no emissions control, ?so should need no vaccum lines to the carb ? right. The vaccum lines have always been my downfall with engine. If it was yours what would you put in or do to it. ( distributor/brain/carb) im open for suggestions.
A 1976 won't have a computer (aka brain box). Perhaps Joe meant a different ignition box? The stock ignition is good enough for your application - and more reliable than any of the aftermarket stuff.
Even if there are no emissions controls, there will still be vacuum lines to the carb. The PowerEnrichment valve is vacuum controlled. The carb secondaries might be vacuum controlled. The little "door" in the air cleaner is vacuum operated.
Your '76 came from the factory with a PCV system - which includes a big fat vacuum line into the intake. Unless it has been removed, there would also be a charcoal canister, though it might not have any vacuum lines to it.
Post details about your setup and I'm someone here will have a vacuum diagram.
dozippy
Does your 460 have an EGR valve?
All you really need from the carburetor vacuum wise, is a part throttle vacuum line going to your vacuum advance diaphram on the distributor and the EGR valve if it has one.
And yes, the big PCV hose. That will be the biggest vacuum port on the carburetor and its full vacuum. That position depends on what carb you put back on.
The transmission modulator and heater control switch ( only vacuum controled if it has A/C ) valve vacuum supply should come from a port on the intake manifold which is also full vacuum.
I don't think I left anything out.
chirvs
52
02-26-2016 07:06 AM
Hagar
07-20-2004 06:28 PM
hotbbb
04-18-2004 09:01 PM
