Power pack for 302
Old Dec 24, 2006 | 09:59 AM
RJBest's Avatar
RJBest
Power pack for 302
Can anyone tell me if a Banks Power Pack will do anything for a ' 94 F-150 w/302 engine? I want more torque and hp for trailer towing.
Old Dec 26, 2006 | 05:00 PM
mrl390's Avatar
mrl390
I was under the impression banks made diesel products. I may not be the brightest light on the string but Im pretty sure the 302 is not diesel.
Old Dec 26, 2006 | 05:33 PM
jimbo beam's Avatar
jimbo beam
unlike diesel trucks, there is no simple plugin box that will give you alot more power.
if im not mistakin most vehicles that can be computer tuned have obd2, ive heard around here obd2 was put into use on ford trucks starting in 1996.
the one programmer i found for my 96 f150 was a hypertech power programer, in terms of power it added alittle but not much.
our trucks are old enough that power has to be added the old fashion way. if your looking for more power, hang a set of headers on it, get a free flowing exhaust, open up the air intake. if you want to get more into it add a cam, better intake manifolds or even a set of heads.
like i said before unlike modern diesels there is no magic box that will give you insane power gains.
Old Dec 26, 2006 | 09:40 PM
MRL123's Avatar
MRL123
Hypertech, I'm pretty sure, USED to offer a chip for the OBD1 computers found in the pre 1996 F150's. I think that retail was around $300.00 or so and basically all it did was fatten up the injector pulse, alter the shift points and advance the timing. Premium fuel was required or the motor would ping itself to death with the new operating parameters. I am in agreement with jimbo beam in that the best way to truly gain power from the 5.0 is to open up the intake and exhaust, cam it as much as the speed density will comfortably handle and drop some free breathing new (AFR, FORD Motorsports, Edelbrock) or re-worked E7TE heads on it. Then you can make some serious power. Of course, you know, you could always bolt on a supercharger-------------
Cheers!
Mike
Old Dec 27, 2006 | 05:37 PM
RJBest's Avatar
RJBest
According to Banks Power, they do. Go to bankspower.com
Old Dec 27, 2006 | 05:46 PM
RJBest's Avatar
RJBest
I guess I was hoping against hope. Your suggestions about the old fashioned way would defininitely do the trick if I wanted to spend the bucks, but with 180K on old Betsy now I hardly think it's worth it. Banks advertises a system for increasing H.P. and torque by up to 68 H.P. and 94 ft.lb. torque which would really help but I don't know anyone who has the system to tell me whether it's worth the investment. Of course the manufacturer will tell you anything to sell it.
Old Dec 27, 2006 | 05:55 PM
RJBest's Avatar
RJBest
Cheers!
Mike
I can see that there ain't no magic bullet. A 302 is a 302 period. I don't want to spend a fortune and I know those heads aren't cheap. I was primarily looking for someone who had experience with a Banks Power Pack. So far no luck! My ' 94 has 180K on it now and although I take good care of the engine it's anyone's guess how much longer it will last. Thanks for the advice however.
Old Dec 27, 2006 | 06:23 PM
cuztom79's Avatar
cuztom79
Smile
i went to bankspower and i didnt see anything for your year f-150 with a gas burner.but for the 300 or more dollars u would spend on a programmer a cam and lifter set would cost less, or u could go with a good set of headers, jba,edelbrock,bbk, ford motorsports
jcallahan83
Aug 12, 2009 08:14 PM
Brandon350
Modular V10 (6.8l)
Aug 28, 2008 12:28 PM
The Sly Wolf
Jan 7, 2004 08:20 PM
info_napl
Modular V10 (6.8l)
Mar 4, 2003 03:07 PM
fujimo
Nov 30, 2000 10:42 PM
