Agreed, when I was stock my GH tunes barely smoked in any setting. The only reason I puke black smoke now is the sticks are still too big for even the 38R. If I had an optimal setup, it wouldn't smoke as bad at all. Properly tuned setups should have minimal soot (exception of turbo spool), then clear to a haze in boost at WOT.
Might be batteries are just week enough and glow plugs lighting drug them down enough to not fire the truck. If they are down on power it will still crank fast but not light off. May want to put a volt meter in while it cranks.
so, truck would only start when plugged in. and fired right up each time after being plugged in. both the glow plug and intake heater relay turned out to be bad. waiting to swap these out, will post up if still no dice.
I have to investigate the tune, to see whats going on with that. fun fun. thanks for the input everyone!
A Excursion does not use a glow plug relay, it has a glow plug controller like whats used on the 6.0 and i believe the california deisel trucks. It should be above the right side valve cover with a green and a black connector from the harness. My connectors burnt up on mine and had to use the 6.0 conversion pigtails from Ford for mine. Same connectors just the wire colors are swapped.
I read that, but mine has the two relays... could the previous owners have converted the glow plug controller module to the standard relay? or maybe they dropped in a new motor? not sure
There's another relay in there that looks damn near identical to the GPR in the SuperDuty's. Can't remember what it's for, but I think that may be what's confusing you...
its got both the relays, the air intake heater relay and glow plug relay.. any official documentation from ford that states ALL excursions had the glow plug module? we jumped the relay and it fired right up
Yes to both.
Joe (GaugePro) changed his wife's Excursion to a GPR setup, removing the GPCM.
Yes, it's in their Online Automotive System Information Service database. OASIS for short.
Only Ford employees with a password have access, unless you know the password of a Ford employee.
This exact same thing happened to me.
1999 Ford 7.3 powerstroke F250.
Bought it new and in 2010 it cranked but no start. Cranked good too. 5 min later battery's were dead from cranking. Put jumpers on from work truck and 10 min later it fired right up.
Replaced the 10 yr old batteries with new ones and problem was fixed.
Was told starter took all voltage and low voltage would not activate some electronic device needed to initiate the fire up sequence.
Stewart
turns out it does have the manual relay, and got it all sorted out. the relay wasn't grounding (after I went and bought two relays), either how the prior owners set it up or that the 'diode' in the pcm is dead and wasn't sending the signal to ground. anyways, got it working wiring it up to a switch. so far has fired up each time. thanks to all for the input, much appreciated.
