Buying upgrades.
Old Feb 6, 2016 | 08:38 PM
sudsmcduff's Avatar
sudsmcduff
Buying upgrades.
Slowly buying stuff for my truck. Just want to know if I am missing something while its apart. Buying-
Frx
New fuel/oil hoses. Hpx done already
Outlet and pedestal for my grp38r
Plenums and boots
Up pipes
Is there anything else in that area I should buy? Thanks
Old Feb 6, 2016 | 08:40 PM
Sous's Avatar
Sous
FTE Leadership Emeritus
FTE Emeritus
Billet compressor wheel from SPX, RiffRaff or Barder.
Old Feb 6, 2016 | 09:16 PM
sudsmcduff's Avatar
sudsmcduff
Is that the upgrade for the 38r? Didn't know they needed a better wheel
Old Feb 6, 2016 | 10:38 PM
Sous's Avatar
Sous
FTE Emeritus
I apologize, disregard my previous statement. The opposite is true from what I have read. As I understand it, your best wheel for the 38R is to stay with the wheel Garrett put in it and not to change it out.
Old Feb 7, 2016 | 08:37 AM
Firefighter 1406's Avatar
Firefighter 1406
Frx
Plenums and boots
Up pipes
Are you going with stock Plenums or Riffraffs billet Plenums?
Old Feb 7, 2016 | 09:59 AM
sudsmcduff's Avatar
sudsmcduff
I guess the billet ones. But may just get the insets
Old Feb 7, 2016 | 10:19 AM
Firefighter 1406
I billet ones are very nice. Defiantly don't ever have to worry about them again. The metal ones with gasket from Ford not so much. Not a matter of if but when.
Old Feb 8, 2016 | 12:12 PM
HKusp's Avatar
HKusp
I went with the inserts only when I did the GTP38R install. The inserts really give you a lot more to bite on with the clamps without worrying about deforming the metal. Those billet ones are nice for sure, but the price tag is too.
Old Feb 8, 2016 | 07:38 PM
Firefighter 1406
I agree. Where not cheap. But figured no matter what I new, new engine, newer 7.3 or whatever. They could come with me.
Old Feb 9, 2016 | 12:56 AM
aawlberninf350's Avatar
aawlberninf350
It's a Van Gogh
I went with the plenum inserts and t-bolt clamps with Dieselsite valley boots. With luck on the passenger side fuel line, I'll never be back in there.
Old Feb 9, 2016 | 09:43 AM
empiretc's Avatar
empiretc
same boat:
https://www.ford-trucks.com/forums/1...ce-please.html
Old Feb 9, 2016 | 01:40 PM
mototrig's Avatar
mototrig
Frx
Plenums and boots
Up pipes
Don't forget the high flow CVD's from Clay. I just swapped mine out this weekend, what a huge fuel suply restrictor the OEM check valves are.
Don't forget to order new fuel line o-rings when you order the CVD's.
Old Feb 9, 2016 | 02:04 PM
sudsmcduff's Avatar
sudsmcduff
What is cvd?
Old Feb 9, 2016 | 02:16 PM
sudsmcduff's Avatar
sudsmcduff
Never mind just googled it. Thanks for that
thx997303
May 4, 2019 06:29 AM
BadDogKuzz
13
Dec 22, 2014 01:59 PM
BIG J82
13
Apr 5, 2010 06:55 PM
Bin Strokin
50
Jul 14, 2006 05:47 PM
ramtruckman
Mar 15, 2004 07:57 AM
