COMPRESSOR WHEEL
Old Apr 5, 2010 | 01:58 PM
BIG J82's Avatar
BIG J82
COMPRESSOR WHEEL
so i must have sucked in some dust and i have some bent fins on my wheel and im only making 20psi
what wheel do guys recomend
is the banks worth the money
or just the 99 03 wheel
Old Apr 5, 2010 | 02:17 PM
JamesHajek's Avatar
JamesHajek
I would go with a wicked wheel like this one. https://www.dieselpowerproducts.com/...ke-170293.aspx
Others will probably chime in and i might be wrong as i dont know much about turbos but i have heard good things about the wicked wheel.
Old Apr 5, 2010 | 02:21 PM
BIG J82's Avatar
BIG J82
yea iv heard of them
im lookin to go to stage one injectors aswell should i leave my 1.10 ex housing or should i go to a 1.0 or even the .86
Old Apr 5, 2010 | 02:34 PM
JamesHajek's Avatar
JamesHajek
what do you do with your truck? do you tow or just a daily driver?
Old Apr 5, 2010 | 02:36 PM
RRranch's Avatar
RRranch
Only 20 psi huh? Must be nice.
The wicked wheel is only an upgrade for 99 up powerstrokes. We already have that one.
Old Apr 5, 2010 | 02:37 PM
powrstrkr's Avatar
powrstrkr
If I'm not mistaken, the wicked wheel is an upgrade for the SD, not the OBS. They changed the wheel on the 99 models. I think it is the exact same wheel ours came with stock. But if yours is trashed it should be a good replacement.
Old Apr 5, 2010 | 02:41 PM
JamesHajek's Avatar
JamesHajek
Ya, its a replacement for our turbos, thats why i gave him the link since his is trashed. If he wants to upgrade then im not sure which one to go with. As far as changing the housing, if your upgrading injectors i think you should stay with stock housing which i believe is 1.15 actually. The smaller housings will just yeild boost faster but it comes with higher EGT's.
Old Apr 5, 2010 | 03:07 PM
BIG J82's Avatar
BIG J82
yea thats what i thought
i heard that the 99 03 compressor is a good replacment for my obs
lol it makes 30 32 psi with an edge and a 3" down pipe and a few other things when the wheel was in good shape
Old Apr 5, 2010 | 03:10 PM
BIG J82's Avatar
BIG J82
daily driver i do some towing
parents 36 5th wheel
14000lb boats at work
Old Apr 5, 2010 | 03:34 PM
JamesHajek's Avatar
JamesHajek
No the SD wheel is a downgrade to our turbos. It is less aggressive.
and i would stick with the stock housing. Your EGT's would be out of control if you went with a smaller housing.
Old Apr 5, 2010 | 04:05 PM
BIG J82's Avatar
BIG J82
really ?? i heard ours is better in the newer trucks cause it takes care of the fluttering
but our turbos dont flutter so the compressor wheel from the newer truck flowed more air in obs
Old Apr 5, 2010 | 04:26 PM
JamesHajek's Avatar
JamesHajek
No our wheel is an upgrade for the SD's because it is more aggressive however the SD wheel is a downgrade for our trucks.
Old Apr 5, 2010 | 06:03 PM
BIG J82's Avatar
BIG J82
so were should i get one
Old Apr 5, 2010 | 06:55 PM
JamesHajek's Avatar
JamesHajek
the link i posted earlier was a wicked wheel for 89 bucks.
lightninquick
Dec 15, 2011 04:08 AM
Jeffery the first
Feb 6, 2011 07:24 PM
nzabka
Jul 25, 2003 07:47 AM
