static drop questions...
Old Feb 7, 2016 | 08:25 PM
  #31
Franklin2's Avatar
Franklin2
I don't see any reason to bag it unless you want it to sit the frame on the ground.
He keeps saying he wants to use this like a truck and haul loads with it. I can't see that happening without airbags of some sort that can be pumped up to haul the load when necessary. I see the rear axle sitting right on the frame with any kind of load on it, especially if he needs a c-notch for the axle to clear the frame.
The airbags may be the only way to have a dual personality for this truck.
Old Feb 8, 2016 | 08:01 AM
  #32
brandonbeezy's Avatar
brandonbeezy
I was definitely going add air shocks for added payload capacity but i want to stay away from air bags as the primary suspension if possible
Old Feb 8, 2016 | 11:02 AM
  #33
FuzzFace2's Avatar
FuzzFace2
ok bag for load carrying I can see that. I would do the load bag before air shocks. Shock mounts are not meant to support weight.
Dave - - - -
Old Feb 8, 2016 | 05:50 PM
  #34
81ChopTop's Avatar
81ChopTop
Dave - - - -
X2 - I would not use air shocks. I've seen many shock brackets wrecked using them. Another option is a Timbren block. Timbren Industries Inc. Suspension Products ? Timbren Industries Inc. Suspension Enhancement Systems and Premium Trailer Suspensions
Old Feb 8, 2016 | 06:17 PM
  #35
FuzzFace2's Avatar
FuzzFace2
That works like the factory HD rear springs in the 250/350 trucks where this load spring is not in use till you put a load in the bed and the rear squats down and the load springs hit brackets to support the load.
I see this rubber spring should be 1/2" to 1-1/2" from the frame to work.
I think I would still go with Air Lift load air bags https://www.airliftcompany.com/
Dave ----
Old Feb 8, 2016 | 07:11 PM
  #36
Franklin2's Avatar
Franklin2
Like the other guys mentioned, you can have your leaf springs and still have a set of airbags in there as auxiliary "helper" springs.
Old Feb 8, 2016 | 07:37 PM
  #37
brandonbeezy
Awesome guy's! This is why I'm on this forum!
Bluey Zedoff
21
Aug 6, 2015 11:00 PM
Wayne Waldrep
Oct 9, 2012 06:59 PM
Pappys53
Jun 22, 2012 11:07 PM
CooGAR
Jan 10, 2011 08:06 PM
cbfatm
Dec 17, 2009 12:40 AM
