Lowering a 1978 F100
Old Dec 16, 2009 | 07:26 AM
cbfatm's Avatar
cbfatm
Hi,
I am new to this forum and I am new to F series fords, my name is Sam
I have just picked up a 1978 LWB F100, in the future I will be putting on big wheels and lowering it, can you make an F100 lower by cutting the springs, or does that not work? I would like the top of the fenders to sit at the top of the tyre,
Thank you
Old Dec 16, 2009 | 02:03 PM
projectbad78's Avatar
projectbad78
you can get by with just a little bit of cutting unless you get your beams bent....theres a couple of lowering threads on here, heres one that you can scrounge thru
https://www.ford-trucks.com/forums/7...ents-here.html
Old Dec 16, 2009 | 06:32 PM
hp246's Avatar
hp246
Welcome cbfatm. You have several options when it comes to lowering your truck. Projectbad is correct in that this has been visited many times. The first question you have to anser is how low do you want to go? If you want the rails riding on the ground, you will want to bag it. A couple of guys have tackled that and they have some great threads and pics. if you want to go 3-4 inches, there are a variety of kits DJM is one top name in the business. I did my 76 with a DJM kit. There are several reasons to go with a kit over cutting springs. First, you retain your alignment numbers. Second, the kits are well engineered and safe. You will find some links here to cutting and flipping springs as well. Remember, if you go that route, you are basically doing your own engineering.
Good luck, and I hope you enjoy the site.
Old Dec 16, 2009 | 08:32 PM
cbfatm's Avatar
cbfatm
Thanks a lot for that,
How much of the springs can be cut? Is the alignment going to be a problem? Any other problems I would encounter? Can I cut the springs a little at a time to see what difference each bit makes? Can I cut both the front and rear springs? Do I have to take the springs out to cut them?
Thank you
Old Dec 16, 2009 | 10:18 PM
jsutton's Avatar
jsutton
Thank you
The hardest part about the alignment is finding a place that still has the equipment, and someone who knows how to align it. You don't have to take the springs completely out to cut them, but you do have to take the two top retaining bolts out so the top of the spring can fall out of the pocket to get access to it. No you can't cut the rear springs, they are leaf springs. You can take them off and CAREFULLY remove a leaf or two depending how many are in the spring pack for some drop.
Old Dec 17, 2009 | 12:26 AM
cbfatm's Avatar
cbfatm
Do'h I knew the rear has leaf springs don't know what I was thinking
Are there aftermarket lowering blocks available for the leaf springs? Or just remove a couple like you said?
When cutting the front springs do you cut from the top or bottom?
Thanks again
Old Dec 17, 2009 | 12:36 AM
projectbad78
you would have to do a flip kit before you could ever use lowering blocks. you can flip your front leaf spring hanger for a few inches or drop shackles
Old Dec 17, 2009 | 12:40 AM
projectbad78
when i chopped my front springs, i took 1 whole coil out and it gave about 2" i believe, cant tell a very noticeable change in the camber, so i dont think it would wear tires too bad, although it hasnt really been driven since so i really cant say
i cut from the top
Remo45
New Member Introductions
Jan 24, 2017 07:23 PM
James Brandon Paul
Dec 27, 2016 09:15 PM
SharkyJ
WTB - Parts & other
Oct 1, 2015 04:23 PM
bigred513
16
Mar 25, 2015 09:17 PM
los80f100
27
Dec 5, 2012 09:08 PM
