Sponsored by: Real Truck
99 sd window regulator problem.
Old Feb 3, 2016 | 03:38 PM
bigguyinmo's Avatar
bigguyinmo
Hey all I have a quick question I hope somebody can answer. I have a 1999 f250 crew cab. About 6 months ago my drivers side window quit working in the up position(lucky me) and last week I got around to fixing it . I just ordered a new window motor instead of the whole regulator and installed it and it worked perfect for 4 days and today it suddenly quit again. What would cause a window motor to go out again so quick? Everything else seems to be fine and there is power to it so I'm assuming it's the motor.
Old Feb 5, 2016 | 11:39 AM
bleeds blue's Avatar
bleeds blue
Did you check the connections? I dont think it would quit that soon, but anything is possible.
Old Feb 5, 2016 | 11:56 AM
wrvond's Avatar
wrvond
Where is the power to? The switch? Do you get power to both sides of the switch?
It's also possible you didn't get the connector completely plugged in and it vibrated off the motor.
Lastly, yes, it is possible for a motor to go bad in four days. It's possible to get a bad motor right off the shelf. If you are feeling particularly energetic, you could plug it in to another switch or door to see if it will drive.
Anderson3476
Sep 19, 2013 10:20 PM
aMw_fl
Aug 24, 2010 09:02 PM
hugo0612
Sep 17, 2007 10:09 PM
aMw_fl
Apr 13, 2007 12:55 PM
dizzead
1997 - 2003 F150
Aug 24, 2006 12:22 PM
