Power window problems
Old Sep 18, 2013 | 06:32 PM
Anderson3476's Avatar
Anderson3476
I am having trouble with my rear drivers side power window. The window will go down but not back up. I assumed the motor was bad so I purchased a new regulator and motor. Got new parts installed new motor goes down, but will not come back up. I've checked fuses, relays, etc what's my next step?
Old Sep 18, 2013 | 06:48 PM
LivingLarge's Avatar
LivingLarge
Did you try exchanging the actual switch from the good side? First thing I would have checked before spending any $. Just my .02
Old Sep 18, 2013 | 07:19 PM
Anderson3476
LivingLarge yes I have done that. I am debating now if I should open one of the other doors and plug the supposed bad motor in to see if it will go both ways there. I am wondering if it is an electrical problem.
Old Sep 19, 2013 | 02:17 PM
h20_guy33's Avatar
h20_guy33
Did you replace the entire track or just the motor? Could be something binding in the track
Old Sep 19, 2013 | 09:33 PM
wallz's Avatar
wallz
Check in the rubber wire boot that the wires run thru to the door. Wires are known to fray in that area from repeated door use.
Tight area to reconnect wiring in also. Ask me how I know.
Old Sep 19, 2013 | 10:20 PM
Anderson3476
Thanks Wallz! I found a broken wire in the boot in the door jam. Got it all back together and running great.
Redneckfordf2502002
Sep 27, 2023 05:05 PM
Methodical_1
18
Jun 12, 2018 08:50 AM
wrhatt
1978 - 1996 Big Bronco
Jun 28, 2016 02:15 PM
sealer700
May 1, 2016 05:08 PM
shotgun64
May 18, 2012 04:00 PM
